sharpening rotary shaver cutters
Home Forums Beginners questions sharpening rotary shaver cutters
  • #6899
    roy entwistle
      @royentwistle24699
      #131790
      roy entwistle
        @royentwistle24699
        Doe's anyone know if it's possible to sharpen rotary shaver cutters ie philips
        or remington I thought possibly lapping on diamond lap I have 600 grit and 1200 grit
        Thanks Roy
        #131805
        jason udall
          @jasonudall57142
          Seen a few worn almost away..out of curiosity looked at edge under glass..still sharp..even with most of flat worn away..so lapping on flat. of the spider bit would be harmless but keep flat. The other half of the shears is probably not serviceable. ..
          #131808
          NJH
            @njh
            Roy
            I solved that problem about 40 years ago – I grew a beard!
            At , say 5min shaving time per day, I reckon that it has saved me around 50days of my life standing in front of a mirror. ( If only I had used that time profitably!)
            Norman
            #131842
            roy entwistle
              @royentwistle24699
              John ( bogstandard2 ) Thanks very much They are titanium so it took more than a few strokes but it worked
              Roy
              #133909
              Ian Welford
                @ianwelford58739
                The Phillips type are designed to stay sharp by rubbing on the underside of the foils ( and self sharoening according to the Phillips rep) so always take them off one at a time, clean and replace in the original foil. They last a damn sight longer that way !
                Just about to start growing a moustache for "Movember" charity drive for Macmillan
                #162531
                helen massey
                  @helenmassey34485
                  Do the cutters and heads only need to be kept as matched pairs after they are put into use?
                  Until they are used, aren't the cutters all the same and the heads all the same?
                  #162582
                    In September? That's cheating!
                    Ian Welford
                      @ianwelford58739
                      see the date it was posted!!!! 27/10/2013 Unless you mean Helen of course….?surprise
                      Helen
                      yes until you "wear them in" the unopened ones are fine. Once you start to sue keep them paired up. It's still ofter cheaper to buy a new razor on offer than get the spares ( currently about £36 for a set of 3 !)
