Setting up and mounting machine tools in a mobile workshop
Home Forums Workshop Tools and Tooling Setting up and mounting machine tools in a mobile workshop
  • #750679
    mark brockley 1
      @markbrockley1
      OK I have my workshop of 2 myford lathes a chester uk  mill and a few other bits. I moved house 16 years ago setting it all up in a building at the new house.  I need to replace this workshop as its decaying and starting to become beyond use. Due to health I am trying to down size and eventually will have to move. I can’t face re building a workshop here then in a couple of years moving it all and setting it up again.  I have bought a cattle trailer and want to make my workshop mobile. My main concern is do I need to mount my benches on rubber mounts
      #750690
      Oldiron
        @oldiron
        If the trailer is reasonably heavy I see no reason to mount the machines on rubber mounts. That could cause problems when moving the trailer around. Good solid mounts and a stable trailer would be the way to go IMHO
        BTW the trailer is on its own rubber mounts 🙂
        #750719
        JA
          @ja
          I cannot see any real problems. The army used to, and probably still do so, put small workshops, including a lathe, in the back of trucks. You may have to careful level the trailer before use.
          JA
          #750724
          Robert Atkinson 2
            @robertatkinson2
            One part of my employers business is mobile workshops for the military. They tend to be in ISO container compatible packaging. I get involved in some aspects of these. There is no resillient mounting of machine tools in these. Set the “workshop” level and level the machines to the same level.
            You could consider a small ISO container but budget to fully insulate and line it oryuo will have terrible condensation problems. Moving it will cost a bit more when the time comes but it will be a better workshop.
            Withem Specialist Vehicles often sell MOD surplus moble units https://www.mod-sales.com/
            They have a couple at the moment but the existing “machines” are not what you want…
            https://bid.mod-sales.com/auctions/9024/witham10160/lot-details/3de34fde-42fb-4aaf-b69e-b1d900bd62c7
            Robert.
            #750732
            JA
              @ja
              There are some obviouses: Strengthen floor (perhaps), weather proofing, electrics, making thief proof.
              I do like the idea of a container (this has been discussed recently).
              JA
              #750737
              Bazyle
                @bazyle
                I cannot see what you thought rubber mounts would help with unless you intended to run the machines while moving down a farm track.
                What you might consider is putting each machine either at the feet or the bed on some kind of frame that provides only 3 point mounting to avoid any flexing of the trailer being transferred to the machine which could in extremis, crack the cast iron.  Interested to hear if the army workshops take this approach.
                Containers are very expensive to have moved, can be 50% of the purchase cost.
                #750778
                Robert Atkinson 2
                  @robertatkinson2
                  ISO containers are very rigid. No need for special mountings.
                  Robert.
                  #750896
                  Paul Lousick
                    @paullousick59116
                    Early Southbend lathes (Hercus in Australia) were used by the army, often in mobile setups and the recommendation was to mount the lathe on 3 points. Headstock bolted down at 2 places and a central point on the tailstock end that could pivot.
                    #750900
                      On Bazyle Said:
                      I cannot see what you thought rubber mounts would help with …
                      I assumed the problem was an expectation that the machines would vibrate on a bendy floor supported by bouncy springs and rubber tyres.   In which case the answer is to stiffen the floor and support it with sturdy jacks.
                      not done it yet
                        @notdoneityet
                        My first thought was whether this ‘cattle trailer’ was new or used.
                        If used, I would be carefully inspecting the frame/chassis of anything that has had animals in it, before mounting heavy machinery in it.
