Setting Tool zero on fixed dial ring lathes
Home › Forums › Beginners questions › Setting Tool zero on fixed dial ring lathes
Viewing 15 posts - 1 through 15 (of 15 total)
  • #137939
    richardandtracy
      @richardandtracy
      I have a Warco WMT 300/1 combi lathe/mill, and is basically identical except in colour to the Clarke 500. The machine is better than I am, so I have no worries there, but I do have a question caused by it having a few shortcuts in its design.
      The dial rings are fixed on the feed screws by woodruff keys, meaning you can't zero the axes or tool when it's in a position you want to return to. I have a work around of keeping a pad of paper and pencil next to the lathe to note down the diameter and feed reading for the tool, then work out the dial reading that should be the desired diameter, stop 0.5mm from that, re-measure and do the final cuts (the calculated and actual rarely coincide due to the tool not being absolutely 100% on the centreline, heating etc).
      My method is pretty laborious though, and I wonder if anyone has more sensible work arounds?
      Does anyone set their tool against a known diameter bar, so that (say) it's touching a 10mm diameter bar at 0 on the dial? Or have any better/quicker solutions?
      Richard
      #6977
      richardandtracy
        @richardandtracy
        #137942
        jason udall
          @jasonudall57142
          Strapping digital calipers to the slides seems popular…
          #137943
          MICHAEL WILLIAMS
            @michaelwilliams41215
            Where index dials are cylindrical fit a slip ring around existing dial . Can be calibrated or just have one fiducial mark to show datum on primary dial .
            Set a dial gauge to detect the zero or any desired offset .
            Full DRO is obviously best but many engineers worked for centuries without it .
            You can set zero by touching a bar but any where I ever worked that would be considered a blacksmiths method .
            The only real test ( in absence of sophisticated equipmemt ) is to skim work , measure and take this positively known diameter as datum for tool position .
            MikeW
            #137945
            richardandtracy
              @richardandtracy
              Mike,
              The latter skim method you suggest is what I do, I was hoping someone had a better (ie quicker & no less accurate!) method.
              Richard
              #137948
              MICHAEL WILLIAMS
                More :
                Unless work is very small diameter minute errors in tool centre height do not affect cutting diameter very much ( nor as a matter of interest does it cause tapers to go crooked ). Most of the discrepancies between applied and measured depth of cut are due to accumulated small errors of human observation , poor cutting action and to variable backlash spring in work and machine .
                Professional workers doing fine work are often pedantic about setting tools , taking measurements and using experience to compensate for known minute defects in machine .
                Just try setting your tool by dial very accurately – using a glass if needs be and get a good feel for using a micrometer properly . Don’t do this every time but just have a trial to see how much difference things like this can make .
                As regards reading micrometers don’t just apply to work and hope for the best . Observe and feel position of micrometer – find the true maximum/minimum diameter by taking several measeurements . Common fault is that the micrometer is held askew by small amount and reading is then too big . Also many micrometers have huge radius but spherical anvils – again find the true reading point in the centre .
                MikeW
                #137949
                Russell Eberhardt
                  @russelleberhardt48058
                  A CD marker pen is useful for marking the dial for the final cut position.
                  Russell.
                  #137959
                  Ady1
                    @ady1
                    Press a button, get 0.00
                    Gives you a fixed datum which is independent of any machine errors/backlash, VERY useful for screwcutting when hundredths of a mm really matter
                    Edited By Ady1 on 16/12/2013 10:37:38
                    #137968
                    richardandtracy
                      @richardandtracy
                      Mike,
                      In practice I use a vernier calliper more often than not. The accuracy I need is to 0.05mm, the calliper precision is to 0.02mm. I mostly work with plastics, which have a noticeable spring in the diameters I use (down to 8.5mm), especially when cutting with carbide inserts (I do this because the finish is better than with my home ground HSS tools and the chips come away as a nice even spiral, when using a less 'pushy' geometry the surface tears). I do use the calliper 2 or 3 times at the mid point of the turning to get the largest diameter and then take the smallest reading. These plastics do expand considerably when heated by working, with rates of expansion easily 1000x that of metals, and the various coloured acrylic alloys I use seem to be much worse than polyesters or 'sensible' engineering plastics. The size of the work precludes a fixed steady, and the travelling steady that came with my machine would have a support point necessitating a doubling of the work length – so no gain there at all. Using a micrometer is problematical on these plastics: I have noticed that there is about 0.1mm compression of the plastic before the micrometer clicks, and if anything my one at home clicks more easily than the ones at work, so it's not faulty, just designed for more rigid materials.
                      Sorry, I'm drifting from the point.
                      A sort of consensus is appearing: If I don't use a fixed digital calliper attached to the machine to act as a DRO, then carry on as I am. Ah well, it's nice to see that I had a reasonable work around to the problem.
                      Richard.
                      Edited By richardandtracy on 16/12/2013 10:57:12
                      #137971
                      Ady1
                        @ady1
                        It's really the time saved, as well as the accuracy
                        If you do do a lot of ME stuff then picking bits up and aligning them to get a decent reading eats up time, and over many years this adds up to a LOT of time
                        Glancing at a DRO and tweaking the leadscrew means more time spent as machine time
                        #137982
                        mechman48
                          @mechman48
                          For final cuts fix a tyre depth DRO gauge to your crosslide with earth magnets ( see my album photos) set 0 & away you go without fear of backlash problems… 0 -1" DRO tyre gauge off eBay for £ 5-6.
                          George
                          #137997
                          richardandtracy
                            @richardandtracy
                            I like the tyre gauge idea. I really like it. I shall go away & investigate. Thanks.
                            Richard
                            #138000
                            John Stevenson 1
                              @johnstevenson1
                              Set your top slide at a slight angle say 10 degrees or so.
                              Take test cut and measure, then advance the top slide a bit and do another test and repeat.
                              This way you get zero on the dial to match up with a workable number.
                              There is a setting on the top slide, can't remember what it is but it works out that 10 units advances on the top slide is equal to one unit on the top slide, supposed to be for very accurate work when the wind allows.
                              #138017
                              richardandtracy
                                @richardandtracy
                                Hmm. 'Tis a thought. But I do seem to be fiddling with the compound slide quite often. In pen making (which currently comprises 95% of my lathework), 3 degree tapers seem very popular, along with 7.5, 10, 15 and 75 degrees, so all the setup goes out the window every time I take a taper.
                                Richard
                                #138025
                                Russell Eberhardt
                                  Posted by John Stevenson on 16/12/2013 13:08:16:
                                  5.7 degrees.
                                  Russell.
