securing a facing cutter on an arbour
Home › Forums › Beginners questions › securing a facing cutter on an arbour
  • #51775
    Ian Welford
      @ianwelford58739
      Guys
      Bought a 5 tipped facing cutter ( Maydown 80mm ) and made a 27mm arbour to fit the same. Arbor ahs a securing bolt to keeop attached to cutter BUT  There is enough movement radially to cause chatter.
      I don’t want to make another arbour , so I’m thinking about stopping rotation of the cutter body around the arbour by adding 1 or 2 either securing pins or cap headed bolts to stop it.
      Questions are-
      1 should the cap head or pins go into the facing flange aginst which the sutter sits?
      2 Alternatively they could go into the 27mm central boss of the arbour.
      I am favouring 1 as then if they shear at any time I can easily redrill but anyone tried it?
      Arbour is nive free machining steel. I know I shoudl have made an arbour with 2 flanges to fit in the drive gaps on the cutter but didn’t see how I could do it at the time without dismounting then remounting the arbour on the 3MT tape which it’s attached to.
      Don’t think loctite will stand the temperatures generated whilst cutting.
      Thanks
       Ian
      #5069
      Ian Welford
        @ianwelford58739
        #51791
        macmarch
          @macmarch
          I presume that your cutter is of the shelllmill type. Does it not have a keyway in the bore? For this size of cutter with the ability to remove large amounts of material at one pass it needs one. I would suggest that you fit a cap head onto the stub mandrel and cut a recess in the bore of the cutter to locate on the head. hth
          ray
          #51794
            Does it not have a keyway along the top face, this can engage on the drive tabs on the end of your spindle nose, looks like most of their cutters have this keyway. Or the flange on the arbour should have some form of drive pins likethese or if its MT 3 then the pins need to extend to engage on the spindle like these
            Edit , reading it again you do have the large top keyway and an MT taper. I would drill & ream the arbour flange for a couple of dowel pins, these can be retained with grub screws from the side of the flange bearing onto flats on the pins. This can be done with the arbour assembled and will transfer the rotational forces from the cutter to the spindle with no risk or turning the MT Taper under load
            Jason
            Edited By JasonB on 18/05/2010 11:24:54
            Edited By JasonB on 18/05/2010 11:26:42
            Edited By JasonB on 18/05/2010 11:32:19
            #51796
            Circlip
              @circlip
              Mill a couple of round ended pockets into the sides of the larger diameter of the arbour and let in a couple of pegs retained with C/S allen screws. Similar effect to JasonBs post but the drive is on a flat surface.
                Send yer E-mail via P/M
                Regards  Ian.
              #51811
              Ian Welford
                @ianwelford58739
                Thanks for the ideas. I like the idea of milling a couple of pins in then securing with grub screws. My idea of cap heads doesn’t give as much contact area but is faster!
                Didn’t know about arbours with transmission pins Jason- thanks for that .
                I think I’ll sleep on it then try the inset pins. If that fails I can always mill the pockets as you say Circlip.
                Should I use silver steel and harden the pins or just use EN1A as is ?
                Despite the chatter I found it works really well at about 800rpn and 25thou cuts! Mind you the steel chips come off blue, as did my language when one found it’s way into my glove!
                Thanks again guys.
                Ian
                #51830
                Terryd
                  @terryd72465
                  Hi Guys,
                  Just a light hearted two ‘pennorth but why are you discussing ‘bowers’, ‘pergolas’ and ‘restful flower covered lattices or trelliswork’ in an engineering publication, surely it should be in a gardening one.  That is an arbour!
                  Or do you mean ‘arbor’ i.e. ‘a machine spindle to support a cutting device’ ?
                  Regards with respect,
                  Terry
                  #51917
                  Ian Welford
                    @ianwelford58739
                    OOps
                    Isn’t an ‘Arbour somewhere to keep boats as well ?
                    Circlip- did you get e mail?
                    Ian
                    #51930
                    Circlip
                      @circlip
                      Sent a reply yesterday at 10.59.17am to the Yahoo address you gave me, re-forwarded today (Friday) at 08.33.18 to same address, perhaps you got the M/E server disease??
                         Regards  antother Ian.
