Screw thread identification No.2
Home › Forums › Beginners questions › Screw thread identification No.2
  • #140123
    Bev Archer
      @bevarcher94647
      Hi Folks,
      Back with my K&B Hornet 15 model aero engine. Thanks to JasonB & Nick I've resolved most of the screw thread queries but the last one really has me puzzled.
      The Spraybar of the Needle Valve Assembly is a brass tube with an external thread. The major diameter , as measured, is 0.138" or 3.54mm but I've been unable to ascertain the pitch as non of my thread pitch gauges cover it. It appears to be between 36 & 40 tpi or 0.6 – 0.7mm. These measurements seem to indicate 4BA but whilst a 4BA nut is a slack fit on the spraybar, the locknut from the NVA is too small to fit on a 4BA machine screw. Also, what would a BA thread be doing on a 1950s American engine? Unless of course my dad swapped the original NVA for a British one.
      Anyway, I hope somebody can cast some light on the dark shadows of my ignorance. I'll be glad when I get onto the British engines, at least I'll recognize the threads there (I hope!)
      Cheers
      Bev
      #7004
      Bev Archer
        @bevarcher94647
        #140124
        Bev Archer
          @bevarcher94647
          Oops! Its a K&B Torpedo not a Hornet.
          Bev
          #140126
          JohnF
            @johnf59703
            Sounds like 6 x 40 UNF, I would check the pitch very carefully sometimes the male thread can become "stretched" thus not giving a true pitch indication. Lots and lots of this on old fishing reels, old guns etc. Just try a 6 x 40 tap or screw.
              BA or Thury would be the only two between 36 & 40tpi around that diameter but as you say unlikely if its the stock needle, I'd go with 6-40 UNF
