Screw cutting is over complicated
Home Forums The Tea Room Screw cutting is over complicated
Viewing 10 posts - 26 through 35 (of 35 total)
  • #429305
      Posted by duncan webster on 17/09/2019 00:36:56:
      I reckon this is where Mr Whitworth got his 55 degrees from, otherwise it's a bit of an odd angle. [ .. ]
      An interesting hypothesis, Duncan yes
      There may be some truth in it … but the evidence suggests that Whitworth's choice was more statistically based:
      [quote]
      In 1841 Sir Joseph Whitworth produced a paper on a universal system of screw threads. He then collected a variety of screws and proposed a universal thread using their average pitch and depth. The result was the 'Whitworth thread' with the depth and pitch of constant proportion, giving the 'V' thread a mean angle of 55 degrees and the number of threads per inch was specified for various diameters. The thread was first introduced in his own workshop and was in universal use by 1858. It was not until 1880, when his standard gauges and screw threads were in common use, that they were officially adopted by the Board of Trade.
      [/quote]
      Ref. **LINK**
      http://www.whitworthsociety.org/history.php?page=2
      Anonymous
        Screwcutting is simple, but it takes a modeller to over-complicate it. smile
        For normal threads I screwcut using full form inserts and plunge cutting, so that the cross slide reads total DOC directly. A lot of my threads are screwcut to a shoulder and using the topslide at an angle would make it more involved to set the axial finish point. With the plunge method it is simple to set the clearance to a couple of thou once before cutting the thread.
        Screwcutting on a CNC lathe often uses the G76 macro. It is untrue to say it cuts down the flank as a default. Annoyingly each manufacturer has a slightly different syntax, but all contain a parameter that controls the infeed angle, a value of zero usually represents radial infeed, ie, plunge cutting. So the angle at which the tool infeeds is set by the operator. I understand that newer controls have an option for infeeding on both flanks, alternately one side and then the other.
        I should add a caveat for manual screwcutting imperial threads on my imperial lathe. I have an Ainjest high speed threading unit which automatically trips at the end of each pass. The trip point is pretty consistent, so it makes it easy to screwcut rignt up to a shoulder, internal or external.
        #429316
        vintage engineer
          @vintageengineer
          Setting over the topslide in a production workshop would get you the sack!
          #429320
          Baz
            @baz89810
            Vintage engineer, you beat me to it, but in a toolroom not setting the topslide to half angle would get you either sacked or demoted to production work!
            #429323
            Mick B1
              @mickb1
              Posted by Baz on 17/09/2019 10:02:55:
              I think both of you are being unfair – I don't recall coming across either production or toolroom chargehands that were so hidebound in attitude.
              If you're cutting a heavy precision thread, and shop availability makes you use a lathe that's rather small for the job, of course it makes sense to use half-angle to get the best chance of making a decent job, production or not.
              In a busy tooroom, there's time-pressure on all sorts of jobs, so if the thread's within easy capability of the machine and tooling, and not especially critical for precision, use of plunge cutting would be well understood.
              I've seen both methods in use in both environments. You might, of course, be required to justify your choice, so you better have yer ducks in a row… wink
              Edited By Mick B1 on 17/09/2019 10:17:53
              #429337
              Baz
                @baz89810
                Mick B1, you haven’t worked in the places I have.
                #429375
                Mark Rand
                  @markrand96270
                  Ok, my turn:- I tend to set the top slide over, but to 63° from normal. That's because the tool post has got 40 positions, which works out at 9° per step. I don't want to have to adjust two dials per cut. Hardinge recommend not exceeding 1,000 rpm for threading, but I rarely exceed 600. Even at that low speed the process of left feed/quick retract/right feed/quick un-retract/increase DOC/left feed, etc. goes pretty darned fast. Five seconds per cycle is taking it easy. surprise
                  #429396
                  Jeff Dayman
                    @jeffdayman43397
                    HA HA HA HA HA etc.
                    I've worked for a few right tartars – Hitler didn't have a patch on 'em – every bit of nastiness they could muster, every minute every day. Not very good toolmakers / machinists either. Still don't know why they acted that way, except maybe they were always treated like that.One guy couldn't hit a thou tol if his life depended on it.
                    (But I've also worked for some really personable and fair ones – and they were very capable ones too.)
                    #429398
                    Tony Pratt 1
                      @tonypratt1
                      Posted by Jeff Dayman on 17/09/2019 18:06:14:
                      HA HA HA HA HA etc.
                      Funnily enough I was talking about this very subject yesterday to my last ever apprentice, I can forgive 'managers' being useless & promoted above their skill level but why do so many of them have to be complete bullying a***holes, who couldn't run a bath let alone a team of people?
                      Tony
                      #429410
                      Ian Johnson 1
                        @ianjohnson1
                        OK you want trigonometry, here we go. Moving the topslide by half the cross slide generates and angle of atan(2) which is 63.4 degrees. The theoretical angle for Whit form threads is (90-55/2) = 62.5 degrees, so the trailing flank will just scrape a bit, which is ideal. I reckon this is where Mr Whitworth got his 55 degrees from, otherwise it's a bit of an odd angle. It does work for metric (60 degree) threads, just scrapes a bit more
                        If cutting a big thread on a small lathe, you could try doing this for half the thread depth, then just advancing the topslide until full width reached, then go back and make it deeper, if you get my meaning. I've never tried this, and you'd need to make sure that SWMBO was out so you didn't get disturbed and lose count, but it should work.
                        Note this is not the same as 'plunge' cutting where the topslide is left alone. This cuts on both flanks at the same time, so the chips collide with each other. Yes it works with big lathes and full profile tools, but I am assured by a man who owns several that industrial CNC thread cutting programs arrange for the tool to be advanced down one flank, presumably by altering the angular relationship between lead screw and spindle. They also reduce the depth of feed to keep the chip volume constant. Watching CNC thread cutting is awesome, it's all done a lot faster than manual.
                        Impressive bit of Trig Duncan thanks. I think I'll stick to a third of depth of cut, that way the trailing edge won't scrape at all. And yes CNC thread cutting is a great thing to watch, not as fast as thread rolling though, it is fast!
                        Ian
