John F's is more like what has to be done on bigger machines. I was thinking in terms of stuff that can run off a normal 3 pin plug as a panic button is fine for breaking that circuit providing it's current rating is high enough. A lot of them are 10A though. Personally as long as these only break current when there is a panic I think they would be ok even at 13A via a fuse.
Don't take any notice of me though. It's your choice. Max power in my case is 1hp so say may be 2 going in.
When a contactor is used for higher currents it finishes up like an NVR switch. Some how energising it holds it in. That could be done with an NVR switch, A panic button can then be added to the power to the nvr switch also any other safety switches in series.
This shouldn't really be used to start and stop the machine. Either the controls on it or even an inverter should be used. If something needs to added it should be an on off switch unit with adequate current rating.
In my youth I did a big box to do this sort of thing with massive contactors capable of switching several hundred amps and breaking a lot more. As it was all in one box I used 240v AC contactor coils to save adding a low voltage supply. The were single contact units that even had arc shutes. They were held in with a latching relay – a normally open contact pair is simply used to energise the coil when the relay is pulled in. I used normal relays for that because I thought the current levels and sparks when they opened and the wiping action when closing would keep the contacts clean. It didn't. They all passivated in a couple of months so had to fit gold flashed one. Those went on working for years.
Just in case some one does a complete diy job. While 100ma or so may sound ok in this case it wasn't. On a later similar job I did use a low voltage supply and smaller relays. I liked the octal base type on the first job as it just needed round holes. More sexy too.
I use the inverter as an NVR on my lathe and for control just as the manufacturers recommend. My miller isn't fitted with one. It's 1/2hp so should be fitted with an on off switch box with nvr built in. To be honest I personally don't see a need for a panic button on this. It's a small machine, (Dore Westbury). Having seen a rather large millers castings crack when some one walled away and left just the feed on I'd choose a wiring method that didn't allow that to happen. Maybe limit switches too.
