Rotary table stepper software, anything free available?
Home › Forums › CNC machines, Home builds, Conversions, ELS, automation, software, etc tools › Rotary table stepper software, anything free available?
Viewing 25 posts - 1 through 25 (of 32 total)
  • #154640
    Ian P
      @ianp
      I have a small rotary table coupled to a stepper motor I also have a commercial stepper driver which just needs step and direction etc inputs.
      What I need now is something like 'Division Master software' to make it a usable tool. I have thought of writing my own programme using a Picaxe IC but don't really want to reinvent the wheel!
      I have a feeling I have seen published projects using PICs and AVR chips but I would rather use something I already know.
      Ian P
      #15042
      Ian P
        @ianp
        Just need step and direction signals maybe from PC
        #154642
        jason udall
          @jasonudall57142
          Depends on what you need from sw..
          Since you have driver for stepper ( I take that from only needing direction and step)…
          Well in the ‘old’ days under w98 you could readily write to printer ( parallel) port..so if your stepper driver is good for 5V levels inputs, a minimal interface would be three wires ..
          Then you could count etc. Display angle ( and do step/angle arithmetic)….even do rate control…..
          #154645
          RobC
            @robc77385
            It's probably overkill, but there is GRBL which is free and used on to comtrol all sorts of machines in the 3D Printing community. It might be possible to adapt it.
            #154673
              Can you program in basic? If so BBC Basic for Windows and a parallel port breakout board should do the job.
              Les Jones 1
                @lesjones1
                Hi ian,
                There is a design using a PIC18 series chip that seems to be almost a clone of the divisionmaster. You have to buy the pre programmed chip for about 9 pounds if Ii remember correctly. I am holiday in Turkey until the 10th with only my Nexus 7. When I get home I will post the details which Ii have on my PC.
                Les.
                #154682
                Ian P
                  @ianp
                  Posted by Neil Wyatt on 07/06/2014 15:33:31:
                  I can just about cobble a programme together using Basic which is why I was going to use a Picaxe. I do have an old laptop but by the time the stepper, a box containing a PSU and laptop etc are all cabled together its a bit unwieldy to use on a cluttered bench/milling machine.
                  I was hoping I could find some existing software I could use or adapt.
                  Ian P
                  the stepper driver
                  #154684
                  Gone Away
                    @goneaway
                    This might help.
                    I built one and it works well.
                    #154685
                    Ian P
                      @ianp
                      Posted by Les Jones 1 on 07/06/2014 16:56:50:
                      Hi ian,
                      Les.
                      Les
                      Division master and its clones generate the stepper waveforms in their processor and output signals to drive the motor coils, I already have stepper drivers which have logic inputs for motor direction and step so unless I had access to the source code (and the skill to change it!) their outputs would be incompatible.
                      Ian P
                      Edited By Ian Phillips on 07/06/2014 17:35:17
                      #154686
                      Ian P
                        @ianp
                        Posted by OMG on 07/06/2014 17:25:15:
                        This might help.
                        That is definitely worth investigating, thanks
                        Ian P
                        #154693
                        Bazyle
                          @bazyle
                          The Arduino version is covered here
                          Without re-reading it I think JS has built one.
                          #154732
                          Les Jones 1
                            @lesjones1
                            Hi I an,
                            The link that OMG has posted is the design that I was thinking of but I did not realise it contained the hex file to programming the PIC chip. looking at the schematic it does not contain the drivers for the stepper motor. The output signals are step and direction which is what most stepper driver boards require. When I get back from holiday I will build one to try out. I think I will have all the parts in stock.
                            Les.
                            #154742
                            John Stevenson 1
                              @johnstevenson1
                              Still over in China for a couple of weeks but I do have some spare boards for Steve Wards controller and some programmed chips but I can't do anything until I'm back later this month.
                              #154769
                              harold
                                @harold
                                Posted by Ian Phillips on 07/06/2014 17:39:33:
                                Ian P
                                Ian, over on CNCzone there lives the original thread where Steve Ward ( 'Kwackers' ) posted his design, Currently running at 62 pages. ISTR Steve has posted here on the MEW forum.
                                HTH,
                                Edited By harold on 08/06/2014 15:00:37
                                #154773
                                Gone Away
                                  @goneaway
                                  Posted by Les Jones 1 on 08/06/2014 06:01:48:
                                  If I can build one and get it to work, Les, you certainly can. I pretty much did it from scratch … etched and drilled the PCB and programmed the PIC.
                                  It was a while ago but as I recall, the only problematic thing was actually finding the PIC.
                                  #154824
                                  joegib
                                    @joegib
                                    There are Utube videos of various versions of Steve Ward's PIC-based controller here:
                                    Malcolm Parker-Lisberg
                                    — and here:
                                    Chris Raynerd
                                    Joe
                                    Edited By joegib on 09/06/2014 03:52:06
                                    #154832
                                    Ian P
                                      @ianp
                                      Definitely going for Steve Ward's design. I will wait until JS gets back to see if he wants to sell his bits otherwise will buy just the programmed chip and make a Veroboard (or wirewrap) version.
                                      Thanks for all the replies.
                                      Ian P
                                      #155011
                                      Les Jones 1
                                        @lesjones1
                                        Hi All,
                                        Back from holiday. Made a start on building Steve Ward's design. I have found a PIC18F452 and programmed it.
                                        Les.
                                        #155020
                                        John Stevenson 1
                                          @johnstevenson1
                                          Ian,
                                          I have everything you need. Will PM you when I get back.
                                          #155035
                                          Ian P
                                            @ianp
                                            Posted by John Stevenson on 11/06/2014 13:07:51:
                                            Ian,
                                            Thanks John.
                                            Have a good trip.
                                            Ian P
                                            #155202
                                            Gone Away
                                              @goneaway
                                              Steve Ward has just posted here (top post on page-1) that he has modified the design slightly, updated the files and has new PCB's in stock.
                                              #155262
                                              joegib
                                                @joegib
                                                Actually the announcement of the change is in Post No 741 on Page 62 of of the CNC Zone thread (i.e. the latest post as of today's date) here:
                                                Announcement
                                                Joe
                                                #155295
                                                Gone Away
                                                  @goneaway
                                                  Hmm …. for me #741 is the top post on Page-1. Your link, Joe, leads me to Page-62 and the earliest messages.
                                                  i haven't checked but it probably depends on personal settings – whether you sort newest or oldest messages to the front (and what the default is for guests). Whatever, Post #741 is the one to look for.
                                                  #155332
                                                  joegib
                                                    @joegib
                                                    Apologies, OMG. When joining a forum I always accept their 'system default' settings so assumed this presented the screen in the same way for everyone who does likewise. Plainly, that's not the case. Anyway, we're now looking in the same place.
                                                    Joe
                                                    #155561
                                                    Les Jones 1
                                                      @lesjones1
                                                      Hi Ian,
                                                      I have just tested Steve Wards rotary controller design built on Veroboad now that the 20 X 4 LCD display has arrived. (I did not have one of this type in stock.) I am only testing it with a stepper motor from an old printer and a TBA6560 based driver that I bought on Ebay. It seems to be working as expected. The only slight problem I had was sorting out the connections to a keypad which I removed from a phone. I will now have to order a stepper motor that is large enough to drive my 6" Vertex rotary table and possible a larger driver module.
                                                      Lees.
