Rotary converter
Rotary converter
Home › Forums › General Questions › Rotary converter
  • #327725
    Andy Sproule
      @andysproule22368
      Hi got my rotary converter up and running 240 to 415.Tried it and ran my lathe the voltages were 419,396 and 389 would this be considered acceptable or is it too far out of balance?
      #25635
      Andy Sproule
        @andysproule22368
        #327728
        Brian Sweeting 2
          @briansweeting2
          Unless it has recently changed the accepted voltage tolerance in the UK is 415 -6% +10% which gives you 390 low and 456 high so you should be okay.
          How is the amperage though?
          Edited By Brian Sweeting on 17/11/2017 22:47:51
          Edited By Brian Sweeting on 17/11/2017 22:49:40
          #327731
          not done it yet
            @notdoneityet
            I don't think balance between phases and voltage tolerances are the same. Three phases all at +10% is not the same as two @ +10% and the other @-6%.
            Whether that would make any difference operationally, I don't know. But we always tried to even out the legs on three phase generators as much as possible.
