Thanks for replies,which reinforce my gut feeling that the benefit of these super-expensive bearings is largely, or perhaps wholly, psychological.
As far as I can gather the ABEC specs relate to the tolerances on the inner and outer diameters of the bearings. My daughter pressed her bearings into the plastic wheels by hand then mounted them on to the nominally 8mm axles. She is a slightly built woman, so I doubt that she would have been able to achieve the force necessary to get a tight interference fit to the axle – which is essential to prevent 'creep', when there is movement between the inner race and the axle which can lead to abrasion. And what is the tolerance on the axle diameter I wonder!
MichaelG thought the claim on the Slick Willies website:
[quote]
When you get dirt into your Ceramic Reds, the ceramic balls will help to re-polish the steel races flat again, providing a self-healing benefit because ceramic balls are so much harder than steel.
[/quote]
was 'questionable'. I think that is a characteristically polite way of saying 'wrong' whilst admitting the possibility of error.
I had a look at the SKF website and they go into all this in mind boggling detail – it's pretty complicated. More than I can cope with at the moment, but enough to convince me that the claims made by the skate people are – well – questionable.
It's just marketing nonsense isn't it?
Robin.
Edited By Robin Graham on 14/02/2021 02:35:26
Edited By Robin Graham on 14/02/2021 02:36:17
