Right hand threads
Right hand threads
Home › Forums › General Questions › Right hand threads
Viewing 25 posts - 1 through 25 (of 48 total)
  • #25597
    vintagengineer
      @vintagengineer
      #324337
      vintagengineer
        @vintagengineer
        Who decided right hand threads would be the norm?
        #324340
        HOWARDT
          @howardt
          Probably the same person who decided which way was clockwise.
          #324341
            I don't know … but I'm sure there's nothing sinister involved
            angel MichaelG.
            #324344
            Tractor man
              @tractorman
              Can’t imagine any other reason than it just happened that way. I know some will say there must be more to it than that but if you reverse every single system left hand threads would be the norm.
              #324345
              Samsaranda
                @samsaranda
                Maybe it has something to do with the predominance of individuals who are right handed. Dave
                #324347
                speelwerk
                  @speelwerk
                  Most likely someone from the European continent, if threads was a British invention left handed would have been the norm. Niko.
                  #324349
                  Robbo
                    @robbo
                    Posted by Michael Gilligan on 29/10/2017 19:53:20:
                    angel MichaelG.
                    Nice one Michael! wink
                    #324350
                    Ed Duffner
                      @edduffner79357
                      Leonardo Da Vinci perhaps?
                      Ed.
                      #324351
                        I reckon it's to do with right handers and they way threads were first cut in wood. Threads were marked on a wooden pole by wrapping a chalked cord around it. Then the thread was chiselled out using the chalked spiral as a guide. Right handed people are in the majority and they naturally wrap the cord to create a right-handed thread. It's quite awkward for right-handers to wind left-handed (and vice versa).
                        I've no idea why being right-handed is more common than being left-handed. I would have expected us to split 50-50. Where's a biologist when you need one?
                        PS Just seen Ed's suggestion about Leonardo da Vinci.  As he was a leftie, I may be in trouble!
                        Edited By SillyOldDuffer on 29/10/2017 20:24:13
                        #324356
                        Speedy Builder5
                          @speedybuilder5
                          Its strange that the French adopted RH threads when everything else seems to be opposite !
                          BobH
                          #324359
                          Martin Whittle
                            @martinwhittle67411
                            Despite (or is it indeed because of?) being a southpaw, I find that screwing clockwise is the natural way to drive a screw.
                            I was still surprised yesterday, replacing our oven fan motor. I saw and fully understood from the interweb that the fan retaining nut was left-handed, but which way did I "REALLY WANT TO" and still try to turn it to no avail? But successful repair job in the end smiley.
                            Martin
                            #324361
                            HOWARDT
                              @howardt
                              Archimedes? But then everything is Greek to some all the time, and only most of the time to engineers until they ask the question here.
                              #324362
                              HOWARDT
                                @howardt
                                Go on, tell me he wasn't Greek.
                                #324364
                                vintagengineer
                                  @vintagengineer
                                  Archimedes screws are left hand threads normally.
                                  Posted by HOWARDT on 29/10/2017 20:45:35:
                                  #324373
                                  Mick B1
                                    @mickb1
                                    They were following the sun, which appears to rotate clockwise through the sky. Hence anticlockwise or left hand threads are 'widdershins' – against the sun.
                                    #324378
                                    Hopper
                                      @hopper
                                      Maybe so that cutting forces in the lathe when screwcutting are against the hefty headstock bearings, not against the more flimsy tailstock, and in those days fixed centre, when cutting a LH thread? (Remembering that in those days lathes were not easily reversible at the flick of a switch so screwcutting was most easily done in the normal forward rotation mode.)
                                      Edited By Hopper on 29/10/2017 23:06:56
                                      #324380
                                      Mike Poole
                                        @mikepoole82104
                                        angel MichaelG.
                                        It makes it easier for dexterous people to tighten them.
                                        #324392
                                        martin perman 1
                                          @martinperman1
                                          Posted by SillyOldDuffer on 29/10/2017 20:21:48:
                                          I've always found that being left handed makes us the clever ones devil
                                          Martin P
                                          #324393
                                          Perko7
                                            @perko7
                                            I suppose it also aligns with common phrases like 'right-hand man' which assign the position of power or authority to the right hand. In many cultures the right hand is used for all the important things like eating, drinking, and social interaction, whereas the left hand is reserved for less appealing duties.
                                            #324394
                                            not done it yet
                                              @notdoneityet
                                              Ever since there were armies (and possibly before that) 'everyone' had to be right handed – couldn't tolerate lefties, with arms on the 'wrong' side.
                                              Even down to about a hundred years sgo, those that were left handed were cajoled into using things right handed. Most machines, by then were only easily operated that way. I doubt if left handed scissors were made that long ago, for instance! (anyone know for sure?).
                                              I put handedness down to mothers feeding babies (after breast feeding). Sat on knee, fed with right hand and baby will try to hold the spoon with the right hand. Possibly goes back to stronger heart beat on the left side (ventricle v atrium) and the way babies were carried.
                                              As for screws, I have no idea except that most screws were tightened once and never removed, which meant it was just the easiest way for a right handed person to use them.
                                              Edited to add that perhaps it goes deeper than hands (and feet).  One eye is nearly always the master eye.  That  may even have arisen from mothers feeding babies thatvway round.  Might just be chicken and egg – which came first?
                                              Edited By not done it yet on 30/10/2017 08:12:06
                                              #324396
                                              Clive Brown 1
                                                @clivebrown1
                                                "Archimedes screws are left hand threads normally."
                                                I was with my grand-son in an adventure play-ground last week.
                                                There were two hand-operated archimedian screws lifting water from a stream several metres to the sand-pit. Both were right-handed, ie clockwise rotation at the top to lift water. All the children that I saw seemed to turn them the correct way without much thought about it.
                                                Edited By Clive Brown 1 on 30/10/2017 08:34:41
                                                #324397
                                                martin perman 1
                                                  @martinperman1
                                                  Posted by not done it yet on 30/10/2017 08:07:56:
                                                  According to my mother I was left handed from day one, my parents made no attempt to try and make me use my right hand but the school did, unsuccessfully, but certain school equipment, desk calculators etc were difficult to use but it made me adapt and now I use both hands just as well with one exception, if you put a knife in my right hand I become incapable of any control.
                                                  Martin P
                                                  #324398
                                                  Ian S C
                                                    @iansc
                                                    Handedness is controlled by the brain, a RH person uses the LH brain to control the RH side if the body and a LH person uses the RH brain. About 10% are left handed, but not all people who appear LH are, some of you will have heard of the Kiwi left hand golfer Bob Charles, He's RH, but when he was a kid the only golf clubs around belonged to another member of the family(aunt, mother, can't remember) who was LH.
                                                    Ian S C
                                                    #324400
                                                    vintagengineer
                                                      @vintagengineer
                                                      To draw the water up they have a left hand thread so when turned clockwise the water is drawn up.
                                                      Posted by Clive Brown 1 on 30/10/2017 08:33:34:
