Reverse thread cutting
Home Forums General Questions Reverse thread cutting
Viewing 25 posts - 1 through 25 (of 40 total)
  • #386827
    martin perman 1
      @martinperman1
      Gentlemen,
      Having read the post regarding the Mini lathe repair there was mention of "reverse thread cutting" can anybody, Jason smiley, please explain this method as I think it would be of use to me particularly as I cant disengage the lead screw and I'm constantly in fear of running into the chuck, are there any pictures to help the little grey cells as well please.
      Martin P
      Edited By martin perman on 21/12/2018 12:21:20
      martin perman 1
        @martinperman1
        #386831
        pgk pgk
          @pgkpgk17461
          This vid as a demo of cutting an internal thread away from chuck.. same sort of process for external- reverse the lathe and cut from the back or with an inverted tool from the front.
          #386833
          not done it yet
            @notdoneityet
            He means starting where you would normally stop the carriage. Nothing more difficult than that to imagine….
            Cutting the thread with the lead screw running in the opposite direction. Try it. Your only fear then will be running into the tailstock – if you bother to use it to support the workpiece.
            #386837
            martin perman 1
              @martinperman1
              Posted by not done it yet on 21/12/2018 12:49:41:
              So do I assume the chuck runs backward and the tool is upside down or is the tool mounted on the other side of the work piece. Not so easy to imagine.
              Martin P
              #386840
                You set everything up as per cutting conventionally but just mount the tool at the rear of the work (right way up) and run the machine backwards. It can be done with a conventional HSS bit or if you use insert tooling and don't need ctr support then the internal threading tool makes it easy to reach around the back without having to move the topslide rearwards. Cut the run out (in) groove as you would so that you can put the cut on and simply switch the lathe on with nuts engaged or engage the nut once upto speed if using the dial. For internal you either need a cack handed bar to cut at the back or mount it upside down cutting at the front.
                Here is one I prepared earlier.
                You set the leadscrew up for a standard right hand thread don't reverse it for left hand cutting. Basically by running in reverse you are following the same helix by unscrewing the thread rather than screwing it on.
                Edited By JasonB on 21/12/2018 13:17:55
                #386845
                Bazyle
                  @bazyle
                  If your lathe can't run backwards or you are worried about the chuck coming loose you really should fit a simple electrical stop switch to the motor that is pushed by the carriage. If you have a lathe that has interlocks like for a chuck guard then check it uses low voltage and wire a plain micro switch into that circuit. If you only have a mains on off control get a sealed switch. google 'limit switch'
                  The Boxford had this as a standard accessory to protect the school lathes from careless children.
                  #386849
                  martin perman 1
                    @martinperman1
                    Posted by Bazyle on 21/12/2018 13:55:54:
                    Thank you Jason, a picture speaks etc, Bazle, my lathe can run in reverse and the chuck bolts to the spindle back plate, this would make thread cutting less panicky as I dont have split nuts and no thread dial.
                    Martin P
                    #386854
                    not done it yet
                      @notdoneityet
                      Deleted
                      Edited By not done it yet on 21/12/2018 14:43:00
                      #386858
                      Speedy Builder5
                        @speedybuilder5
                        What ideas do the team have to lock the chuck onto the spindle nose when cutting in reverse or rear tool post parting off. Typically on a Boxford with screw on chuck.
                        BobH
                        #386861
                          That is already planned as the first second mod to the SC4!
                          Ron Laden
                            @ronladen17547
                            Posted by martin perman on 21/12/2018 14:20:57:
                            Martin P
                            Which lathe do you have Martin
                            #386870
                            Anonymous
                              It should be noted that external and internal full form threading inserts do not necessarily produce the same form.
                              Of course only a dedicated follower of over-complication would know about that sort of thing. smile o
                              #386880
                              martin perman 1
                                @martinperman1
                                Posted by Ron Laden on 21/12/2018 15:33:52:
                                Martin P
                                I have a Clarke CL500M which does nicely for me,
                                Martin P
                                #386899
                                  Posted by Andrew Johnston on 21/12/2018 15:44:09:
                                  Andrew, if you happen to know any people like that you may want to let them know that if you put a full form external LEFT hand insert into a RIGHT hand internal holder you can use it at the back of the machine and get the correct profile, though I expect they know that alreadywink 2
                                  #387084
                                  Howard Lewis
                                    @howardlewis46836
                                    Some of the later Eastern lathes (examples are:Warco BH600, BH900, Chester craftsman, Engineers ToolRoom BL12 – 24. And probably others) with screw on chucks have dogs which hook behind the flange on the mandrel, do that the machine can be run in reverse without fear of the chuck unscrewing.
                                    Possibly, it may be possible to devise something similar for lathes without this feature.
                                    Maybe even a small grubscrew and brass pad to bear on the thread, if space allows?
                                    At times, I used to run my ML7 in reverse, having made sure that the chuck was firmly in place (not so firmly that it could not be removed without undue force) . But slowly, and without taking big cuts!
                                    #387111
                                    Jon
                                      @jon
                                      I used to have serious trouble unscrewing my old ML7 chucks, always needed spindle locking down and a hard sharp smack on spanner or gripped bar in the jaws.
                                      I often turned in reverse, machine cut better that way.
                                      #387112
                                      Anonymous
                                        Posted by JasonB on 21/12/2018 17:07:10:
                                        Andrew, if you happen to know any people like that…………….
                                        Nope, don't personally know anyone like that. smile
                                        Surely a LH insert may not have the correct clearances? Not that I've got any LH inserts as thus far I've never needed to cut a LH thread.
                                        Think I'll stick to the conventional method of screwcutting.
                                        #387127
                                        fishy-steve
                                          @fishy-steve
                                          Posted by Speedy Builder5 on 21/12/2018 14:52:25:
                                          BobH
                                          Hi Bob,
                                          As far as parting off with a rear mounted tool post, just invert the tool and run in the conventional manner.
                                          I do it that way on my Boxford.
                                          Steve.
                                          #387134
                                          Speedy Builder5
                                            @speedybuilder5
                                            hi Steve, yes, but you are "lifting"the saddle off the bed. On the Boxford, there is a rear saddle clamp, and a front saddle/ bed lock, but its a fiddle trying to tighten the rear cap screws when they are inverted and out of sight.
                                            #387141
                                            fishy-steve
                                              @fishy-steve
                                              Posted by Speedy Builder5 on 22/12/2018 16:51:48:
                                              Hi Bob,
                                              I never have to tighten the rear saddle clap screws when parting off with HSS..
                                              I purchased a parting tool from JB cutting tools at the midlands show this year. My Boxford can easily part off in the conventional manner when using it. I have yet to try it in the rear tool post. I think this would probably be the best set up though.
                                              Steve.
                                              Edited By fishy-steve on 22/12/2018 17:31:31
                                              Edited By fishy-steve on 22/12/2018 17:31:48
                                              #387313
                                              larry phelan 1
                                                @larryphelan1
                                                You would need to be threading very near to the chuck to be in any danger of running into it,no thread goes right up to the chuck.
                                                I leave the leadscrew/halfnuts engaged all the time,while threading,using the angled top slide to set the dept and the cross slide to put on the cut. When you reach the end of your cut,wind out the cross slide and reverse the lathe back to the starting point,while bringing in the top slide a bit deeper. You get into the habit of using both of them together,and it works a dream.
                                                Sparey was using this approach back in his day,and it still works.
                                                The only time I have to watch it,is when I,m cutting large threads like 21/4"x 8 as on my lathe spindle,since the carrage is really moving and while I might not hit the chuck,I could run out of road,so to speak. Result is much the same. Chips might not be blue but the air sure is !
                                                Lathes do not like things like that.
                                                #387316
                                                martin perman 1
                                                  @martinperman1
                                                  Posted by larry phelan 1 on 23/12/2018 17:11:07:
                                                  I do not have half nuts to disengage and I cant disengage the feed as I will not be able to pick the thread up again, I dont thread close to the chuck but I've made adjusting screws with large heads and have run into them because backing the tool off then stopping the lathe and putting it in reverse and starting it again can get very frenetic. I find the slowest speed on my lathe is a bit quick for thread cutting also and my next project was a three phase motor and an inverter but the budget has just been blown on sorting my car out.
                                                  Martin P
                                                  #387341
                                                  Paul Lousick
                                                    @paullousick59116
                                                    Another option, if you are afraid of running into the chuck (or shoulder on shaft) while screw cutting is to fit a crank handle to the spindle and turn it by hand.
                                                    Paul.
                                                    #387386
                                                    Ron Laden
                                                      @ronladen17547
                                                      Posted by martin perman on 21/12/2018 12:20:33:
                                                      Gentlemen,
                                                      Martin P
                                                      I didnt realise that there are lathes where you cant disengage the lead screw, how do they work..?
