removing harrison l5 apron
Home Forums Beginners questions removing harrison l5 apron
  • #401108
    Thomas Shannon
      @thomasshannon38993
      hi everyone, new to the fourm. having some issues trying to remove the apron, the only thing holding me back now is the feed box underneath hitting the end block for the lead screw and feed screw. any suggestions around this ?
      Thomas Shannon
        @thomasshannon38993
        #401127
        Thomas Shannon
          @thomasshannon38993
          just ended up splitting the apron.
          #401604
          Nigel Graham 2
            @nigelgraham2
            Which way are you trying to remove it?
            When I dismantled my L5 to move it (it was the only way available), I removed the leadscrew and feed-shaft completely, chocked the underside of the apron with blocks of wood then separated the apron from the saddle by removing the Allen screws that hold it up.
            There also a couple of dowels in there so be sure to lower it and refit it vertically.
            Obviously, take the leadscrew especially out carefully and slowly, with as much support as you can give it, so you don't bruise its and the half-nut's threads against each other.
