releasing tapers
releasing tapers
Home Forums Beginners questions releasing tapers
Viewing 21 posts - 26 through 46 (of 46 total)
  • #395799
    Howard Lewis
      @howardlewis46836
      With regard to using the taper in the mandrel, I do.
      Useful to maintain concentricity of a part that is going to be turned, milled or gearcut in the lathe and then the Mill/Drill.
      If, for instance, I am turning a blank for a gear, the small chuck with a 2 MT shank is sleeved up to that of the Lathe mandrel.
      In that way the diameters turned in the lathe should remain concentric when the 2 MT chuck is moved to the HV6 Rotary Table for cutting the tooth spaces.
      Without using this method, there would be a need to clock and centre in a four jaw chuck.
      Must all depend on the purposes for which the machines are used.
      Clive Foster
        @clivefoster55965
        I suspect that vibrational effects are much more important in taper release (and initial gripping) than is generally recognised.
        I recall the flywheel extractor for the engine on an Acto rotary mower we had maybe 40 years ago. A simple round steel bar, maybe 6 or 8 inches long and 3/4 – 1" ish diameter, screwed on the end of the crankshaft after the flywheel nut was removed. With an assistant applying upwards force by holding the flywheel on opposite sides a sharp rap with an ordinary hammer on the top end made the bar go "Riiing" and the flywheel jump off its taper just like that. No levers involved. Simply held up by hand. As the holder when we first tried youthful Clive was very surprised. So was Dad. So much that we put the thing back on. Verified that it was still totally immobile by conventional means including big pullers, large levers et al and tried again with identical ease. At the time I wondered if there was some magic length and frequency involved but these days I think pretty much any adequately high frequency of vibration would have done. Being a nut welded on a piece of bar the thing was hardly sophisticated!
        Getting back to machine tapers I'm probably not the only guy to notice that a dead-blow hammer needs a lot more walloping to shift a taper than an ordinary steel one. Hardly surprising if vibration is involved as dead-blow hammers are all about creating a solid push to shift things with minimal vibration. These days I strangle a club hammer and hit the drawbar on my Bridgeport with a sharp twist of the wrist to release things. Surprised the heck out of a sometime toolmaker friend who was borrowing the machine when my way shifted a stuck R8 with a single rap when a couple of minutes of his efforts with my big dead blow had failed.
        My take on the tang issue is that with decent tapers in the spindle and on the drill only a modest push is needed to hold things well enough to start drilling. With the tang stopping rotation any vibration during drilling will act to push the drill harder into the taper. Sufficiently so that it will stay put if cutting conditions cause it to try to pull out. Without the tang the drill will be free to rotate if vibration or pull-out loosens the taper. Once rotation starts its pretty much impossible to stop. I have actually seen this happen with a moderate size drill whose tang had been removed. Said drill had been seriously walloped into place with a hammer and copper block but to no avail.
        It usually seems to me when removing a taper drill that its in a lot tighter than initial insertion force plus drilling force. Vibration working things tighter could be why.
        Clive.
        #395808
        Anonymous
          Posted by SillyOldDuffer on 11/02/2019 12:28:34:
          My guess is the tang is only there to stop an accidentally loose taper spinning in the socket and damaging the machine. Tangs might be less popular today, at least on automatics. I suspect many modern machines can detect when a tool isn't cutting properly and reject it automatically, or stop and alert the operator. Perhaps a CNC expert will tell me I'm dreaming again?
          Well, I'm not an expert, but I can't offhand think of a commercial CNC mill that uses Morse tapers. They all use autochangers so the holders have pullstuds rather than tangs. Most holders are variations on the International series of tapers.
          Simliarly I can't think of automatics or CNC lathes that use tangs. The old capstan lathes used parallel holders, and you could get Morse taper holders with an ejector slot for the tang. Most modern CNC lathes use a generic standard like VDI or one proprietry to the manufacturer. I suspect Morse taper drills are not used on CNC lathes; better to use those based in inserts for better repeatability
          #395818
          larry phelan 1
            @larryphelan1
            Dave [S-O-D ]
            I saw that hint about the timber cover for the lathe bed in Sparey,s book many moons ago,and it was the first thing I made for the lathe. It,s a lot cheaper than trying to repair a damaged bed if a chuck slips at the wrong moment.
            As an aside,I often wondered about those tangs too,I thought at one time that they were there to provide the drive.
            And yes,some MT centers are shorter than others and can get stuck in the tailstock.
            How do I know???? ASK ME !!sad
            #395819
              Looking at my reprint of Chas A Strelinger & Co's catalogue of 1895 they show the "Pratt Improved" drill chuck which will hold round or tapered drills and uses a plate with rectangular hole to fit over the tang to provide drive, the two opposed jaws are there to ctr the bit and stop it dropping more than to provide drive.
              If using taper shank drills a split sleeve is used to convert the bit to parallel shank.
              #395830
                Allowing a taper shank to spin in its socket damages both rather badly. Galling, tears, scratches and loss of circularity. Once damaged, slipping and even more damage becomes ever more likely. Although shanks are cheap and easily replaced, the socket is part of the machine and fixing it less straightforward. In a world where machines not busy cutting metal are nothing but a waste of money it pays to protect the machine from outages due to accidental damage.
                I think that ^^^ explains it very nicely, Dave … not least because I have the same ingrained as a 'folk memory' [which probably means my Dad told me].
                If the taper slips, the tang abruptly stops it rotating far … ergo, the shank is more likely to drop out than to be friction-welded into the socket.
                [still searching for Colt's patent]
                #395835
                not done it yet
                  @notdoneityet
                  MG,
                  I think that is what I alluded to about a page ago?
                  #395842
                    Posted by not done it yet on 11/02/2019 19:24:55:
                    MG,
                    It may well be … but allusion and elaboration are rather different things.
                    P.S. … I hope you have also noticed that my posts on this topic have been generally supportive of you.
                    ___________________________________
                    Edit: Perhaps your posing of a direct request might explain why people felt it appropriate to discuss the matter further.
                    [quote]
                    Look guys, I know the drive should be friction between the tapers, but answer me this:
                    [/quote]
                    Edited By Michael Gilligan on 11/02/2019 19:57:11
                    #395845
                      Some fascinating images of Colt's machine-tools here: **LINK**
                      https://books.google.co.uk/books?id=T9e37mYzuNIC&pg=PA175&lpg=PA175
                      Kiwi Bloke
                        @kiwibloke62605
                        Clive Foster's Atco experience is fascinating – I must try to remember it for future use.
                        I've been thinking about releasing things stuck in tapers. I hate whacking the things free – it must do the bearings a power of no good. Self-ejecting arrangements, captive draw-bars, folding wedges and threaded collars at the nose end are so much gentler.
                        The trouble with thinking is that the more I think, the confuseder I get. When a bullet is fired, the back of the bullet starts moving before its nose. A compression wave spreads out through the bullet at the speed of sound (ie the speed of sound in whatever the bullet's made from). This causes the bullet to be plastically deformed – if it can 'go' anywhere – increasing in diameter, and contributes to the bullet being forced into the rifling grooves, and stops gas leakage. (Impressive and somewhat hair-raising experiments were done in the early 1900s by F W Mann, which involved the recovery of fired bullets without their suffering significant damage after they left the gun.)
                        Something similar (although elastic) presumably happens when the tang or small end of a tool in a taper socket is whacked. I would suggest that the whack will cause a transient increase in the radial forces between the tool and taper. Perhaps, if the whack is smart enough (not from a dead-blow hammer), the compression wave is followed by a 'tension' wave, which helps release. It would be better, (wouldn't it…?), if the blow could be applied at the large diameter end, so that there was only a wave of tension. Perhaps a slide-hammer puller, applied to the outboard end of the tool, or whacking a rod lying in a deep axial hole, bored from the small end, the end of the hole being beyond the wide end of the socket.
                        If this sounds crazy, just think about how you'd get a long rubber plug deep into a tube with an ID smaller than the plug's OD. You'd easily pull it in, but pushing would be impossible. I believe this is how the trailer 'Indespension' units were assembled (are they still going?).
                        This isn't meant to be a serious practical suggestion, just thought-provoking. Perhaps I should have gone to bed before now…
                        #395906
                        Hopper
                          @hopper
                          Methinks pressure waves in soft lead bullets under the power of explosive gunpowder may be a different kettle of fish from a tap with a tapered drift on a tough tool steel taper shank. Hard to imagine similar amounts of deformation going on. Maybe to a certain extent? Maybe. But more likely you just tap the thing and its pushed out.
                          Edited By Hopper on 12/02/2019 10:06:48
                          #395924
                          Chris Trice
                            @christrice43267
                            Agreed. Given the amount of energy imparted into the taper with a whack, I can't see any appreciable deformation occurring in such a large solid mass since most of the deformation would occur in the tang (or at least very locally to the point of impact) as the rest of the material directly behind it absorbs the energy. Anyone who has tried to whack the threaded part of a steering rack ball joint to get it to release will be familiar with the thread getting deformed. Certainly the thrust forward is going to massively overcome any increase in friction from whatever negligible expansion occurs.
                            #395929
                            Reg Rossiter
                              @regrossiter24538
                              RePosted by not done it yet on 11/02/2019 08:26:08:
                              Look guys, I know the drive should be friction between the tapers, but answer me this: Why was a tang fitted, when a dome (or even flat surface) would have sufficed as a point of action for the wedge? Why was the drill only able to be inserted in that orientaion.
                              In other words, was the tang a poor design or was it there as a back up tell-tale sign (that all was not well) before the taper surfaces were totally screwed up?
                              I’m not a mechanical engineer, so please give me a good design reason why the tang was developed in that shape, ‘cos those guys that designed it had a good reason for that shape. If it would have been better just flat topped, that is how they would have done it – simpler and faster not to have to locate the tang in the spindle slot, for instance.
                              The reason a tang is preferable to a domed or flat surface is down to maintaining the strength of the spindle. In order to use a taper drift you have to put a slot right through the spindle which weakens it. If you were going for the domed or flat ended option you would have to continue the round, tapered bore up into the ejector slot. Therefore at this point in the spindle you would have a round bore and a slot reducing the cross sectional area of the spindle and therefore the strength. Using a tang means that the tapered bore stops as the tang slot starts and leaves the spindle stronger.
                              Reg
                              #395931
                              John McNamara
                                @johnmcnamara74883
                                Hi
                                A very handy site that covers Machine tapers is this one.
                                If you have an old taper you are trying to identify chances are it will be listed.
                                not done it yet
                                  @notdoneityet
                                  Reg,
                                  I can understand that might be true, but the dome would not actually need to be much more than a button – the wedge should only act vertically downwards at the centre line of the spindle. Therefore the wedge slot could be much further down the spindle than it actually is? Likely a simpler manufacturing process for the spindl, too.
                                  Seems to me that maybe the driving taper came after the adoption of a tang drive, as more powerful machines entered the market?
                                  #395976
                                  HOWARDT
                                    @howardt
                                    For what it is worth. Locking tapers e.g. morse, create a friction lock by virtue of there shallow angle. An included angle of less than 14 degrees will provide a friction lock when tapped into place. But this lock will remain in place so long as the major force is along the centre of the taper. If vibration or/and side loads occur then the taper may release. The Morse taper or Brown and Sharpe taper are both available by design with a tang which is designed to allow disassembly of the inserted taper in a spindle by applying an angled drift. The tang has a clearance in the spindle slot of 0.010" nominal, with this in mind any rotational force will act as a point load initially on the tang. It is not uncommon on worn drill presses to find a number of drills with twisted tangs, Twisting seems to get worse as the taper size increases. probably due to the blacksmith element of the larger drilling machines. So using a locking taper with any vibrational tooling, such as milling cutter will require a draw bar. The drive tang gives a long contact face with the drift, a domed pin will give a line contact so deformation of the either the pin or the drift will occur at each release.
                                    CNC and conventional metal cutting machines use a non locking taper with the drive being made by a couple of face keys. Retention being made by a draw bar through the spindle is locked either manually or by hydraulics and spring packs.
                                    i'll stick with convention and accept that standards are there for a reason even if that reason has been lost in time. I am sure some one will find an original document showing why soon.
                                    #396055
                                    Kiwi Bloke
                                      @kiwibloke62605
                                      OK Hopper, I'll bite…
                                      '…a different kettle of fish…' Very good! Clearly a sly pun, alluding to the Poisson ratio, which is of central relevance to what I was rambling on about!
                                      Clearly, following a whack on the little end, the outwards deformation of the inserted male member (can I say that on this forum?) in the female socket will be miniscule, but would be detectable with a strain gauge on, say, the outside of a tailstock barrel. A compression wave will indeed travel through the tool (and socket): (elastic) deformation will not be confined to the tang. And, of course, whacking the thing (usually) gets it out, so any transient increase in the friction holding the things together will be overcome. However, given Poisson's insight into deformation mechanisms, pulling things out of tapers should be easier than pushing – although perhaps less practicable. That was my message – for what it's worth.
                                      Anyone who has used a Clarkson 2MT collet milling chuck, with its 'steadying ring', will know how readily tightening the ring can release the taper. Ideal geometry for release.
                                      I'm not trying to labour a point here, nor wishing to disagree with anyone – just indulging in a bit of theoretical whimsy – but I always cringe when anti-friction-bearing-supported bits of machine get attacked by hammers. Unfortunately, often there's no sensible alternative.
                                      #396057
                                      Mike Poole
                                        @mikepoole82104
                                        Myford do not construct their tailstocks to use the tang, if the taper lets go the drill spins. This has happened to me a couple of times when drilling something grabby that the drill has pulled it self into and released the taper, this has done no harm at all to the taper, the taper shank and tailstock taper have both been in A1 condition when this occurs. I think it may reinforce the theory that pulling a taper apart is very effective.
                                        Edited By Mike Poole on 13/02/2019 10:21:02
                                        #396061
                                        Hopper
                                          @hopper
                                          Posted by Kiwi Bloke 1 on 13/02/2019 10:03:41:
                                          I never cease to amaze myself. An unconscious genius, I tells ya.
                                          #396064
                                          Kiwi Bloke
                                            @kiwibloke62605
                                            Probably best not to add complication to the tang discussion by mentioning 'use-em-up' sleeves.
                                            Wish I hadn't.
                                            #396065
                                            Hopper
                                              @hopper
                                              Posted by Mike Poole on 13/02/2019 10:20:25:
                                              Agreed. The tiny MT1 taper on my old Drummond M-Type tends to let go occasionally when the old Flagellator is pushed hard. So much so that the ancient drill chuck that came with it finally would no longer grip. All the wear, corrosion and dents fom over the years were on the taper shank on the chuck. Inside of the tailstock barrel seems just fine. As pic posted way above shows, new chuck with new taper shank will hold a 1" drill firm without slipping. I don't think a spinning taper every now and then is a catastrophic problem.
