My lathe, a Warco 220/Mashstroy C210T has a self-ejecting MT2 tailstock. Originally I used a drill chuck with a MT1 taper on the end which I fitted into a MT1-MT2 adaptor. In this mode it worked satisfactorily, but suffered from a large tailstock travel loss. Eventually I replaced the MT1 taper with the correct adaptor for the chuck and gained some, but not all of the missing travel. I then removed the tang, rounded the end, and found that I had removed too much! Ok mea culpa, but tool removal became difficult so I had to add a bit of metal back on to the end of the MT2 taper – a thick washer araldited in place.
Same thing happed with my running centre. (You would think I had learned from the drill chuck attempt, but actually I did them both at the same time.)
So, the point I am making is that in my case, there is a sweet spot for tang reduction to enable full travel of the tailstock, along with correct self-ejection. I think it may have been the late John Stevenson who, correctly I believe, said that this looks like poor tailstock design. However, bodging like this is possibly the best way forward for my lathe.
In respect of using them on other lathes etc, it will not happen here – I only have the one lathe. What happens when I have finished with this lathe is very unlikely to concern me – the lathe itself is not the best in the world and will only go for a low price. In anycase, if it is sold, it will probably be sold as a job lot, ie lathe & accessories. In any case, the adaptors are reasonably cheap and can be easily replaced if necessary.
Peter G. Shaw
