regulator valve
regulator valve
Home › Forums › Beginners questions › regulator valve
  • #331704
    Philip Burley
      @philipburley44197
      I am just on the point of machining the valve and gland for my 2 inch traction engine . Does the valve need to be a tight fit over the rising steam hole ? the plan is a bit vague on the fit needed , surely the steam pressure will tend to force it off the seat when its closed and there is no pressure in the chamber ,Or am I missing something ?
      regards Phil
      #8996
      Philip Burley
        @philipburley44197
        #331716
          What traction engien is it?
          Usually the steam passes around/through the cylinder and up into the regulator chest, this holds the valve down onto the passage that links reg chest to valve chest.
          #331737
          Philip Burley
            @philipburley44197
            Ah, so I have it wrong then, the steam is already in the regulator chamber and its the opening into the slide valve chests that is uncovered . I was thinking that the valve uncovered the opening from the boiler . It's ransom simms and Jefferies 2 cylinder
            Phil
            #331740
              That's it the drilling up from the boiler is not covered so the reg chest is under pressure ( also the safety valve and whistle) then the valve controls the flow out of that chest into the shorter drilling that branches off to the valve chests.
              #331773
              Philip Burley
                @philipburley44197
                yes its obvious when someone points its it out to you , Trouble is the plan I have is drawn by someone who knows what they are doing for someone who also knows , All the parts are there but not how they go together , Still its coming together slowly . Thanks for the help
                phil
