Reamering cast iron – lubrication
Home Forums Beginners questions Reamering cast iron – lubrication
  • #343578
    Martin Dowing
      @martindowing58466
      To lubricate or not to lubricate, that is a question?
      Edited By Martin Dowing on 28/02/2018 08:06:03
      Martin Dowing
        @martindowing58466
        #343579
        Brian H
          @brianh50089
          Definitely not lubricate! The reamer will cut dry but any lubrication will make it slip.
          #343580
          John Haine
            @johnhaine32865
            No, and reaming. But take it slow and clear chips frequently.
            #343584
            Grindstone Cowboy
              @grindstonecowboy
              I would certainly go with the advice of the experienced members of the forum.
              However…. I did read in an old article (c. 1905) that reaming with oil makes a smaller hole than reaming dry, but it did NOT specify whether that applied to cast iron. Possibly the built-in lubrication of cast iron makes it irrelevant, but I was wondering if this was actually true and why it might be?
              All I can think is that dry reaming cause the non-cutting edge on one side to drag a miniscule amount and force the cutting edge on the opposite side to take a bigger "bite", for want of a better word.
              Is it true, and if so, is my theory correct? Apologies for hi-jacking the thread, but I thought it was kind of relevant to Martin's question.
              Rob
              #343599
              Brian H
                @brianh50089
                Bob, there isn't a non-cutting edge, all edges will cut when the reamer is turned in the correct direction.
                #343603
                Jon Gibbs
                  @jongibbs59756
                  I seem to remember Stefan Gotteswinter saying that lubricating with cutting oil leads to a larger reamed hole than using water soluble oil but this wasn't in cast iron.
                  I can't find the actual discussion now but there is something at 14'30" in this video **LINK**
                  …where he's using water soluble oil and a very close bored starting hole for the snug suction fit on a dowel pin.
                  HTH
                  [Edit: Just found this https://ttu-ir.tdl.org/ttu-ir/bitstream/handle/2346/15032/31295005186092.pdf?sequence=1. See pages 29 onwards – a whole PhD thesis on reaming!
                  Dry leads to the biggest holes in general and less viscous oils lead to less oversize with soluble oils leading to best surface finish and potentially undersize holes.]
                  Jon
                  Edited By Jon Gibbs on 28/02/2018 09:32:22
                  Edited By Jon Gibbs on 28/02/2018 09:43:11
                  #343604
                  larry Phelan
                    @larryphelan54019
                    I understood that cast iron was always machined dry ??
                    #343610
                    John Hinkley
                      @johnhinkley26699
                      Jon Gibbs' reference to Stefan Gotteswinter's video is when he's making his cylindrical grinding attachment, here:
                      at about 26 minutes et seq. As Jon said, that isn't in cast iron, however, and I would not use any form of lubrication myself on such material.
                      John H
                      Edited By John Hinkley on 28/02/2018 09:44:44
                      Edited By John Hinkley on 28/02/2018 09:45:20
                      #343616
                      Jon Gibbs
                        @jongibbs59756
                        Posted by John Hinkley on 28/02/2018 09:44:02:
                        Thanks John.
                        #343624
                        Martin Dowing
                          @martindowing58466
                          Hi,
                          Many thanks for comments.
                          Have decided not to lubricate, like usual with cast iron.
                          What diameter of drill would you use before reaming to 4mm? I suspect that 3.8-3.9mm is correct.
                          With larger diameters (6-20mm) I was always using drill 0.2mm smaller, at 20-30mm it was 0.3mm smaller but I have never reamed such a piddly little thing.
                          Martin
                          #343627
                          Grindstone Cowboy
                            @grindstonecowboy
                            Thanks for all the information, chaps, there's always something new to learn thumbs up
                            #343629
                            mechman48
                              @mechman48
                              Ream dry. Do you need to ream such a small hole? you may find that drilling with a 3.9mm drill will give you 4mm dia. hole taking in to account any run out / lip length discrepancy in the drill. If you must ream this small size the I suggest you go to a 3.8mm drill but take it slow & clear out chips frequently, this will give you the max allowance of .008".
                              George.
                              #343637
                              mechman48
                                @mechman48
                                FYI…
                                ​Ref… Presto Engineers Cutting Tools.
                                George.
                                Edited By mechman48 on 28/02/2018 11:12:51
                                #343666
                                Martin Dowing
                                  @martindowing58466
                                  Many thanks,
                                  Now I know how to proceed with that.
                                  Martin
                                  #343670
                                  Speedy Builder5
                                    @speedybuilder5
                                    There are several different types of cast iron. We are probably talking about Grey Cast Iron here which I would ream dry, however the much harder White cast iron (Drain pipes ?), I would use a lubricant to protect the reamer.
                                    Other types include Spheroidial Cast Iron, Malleable Iron, Ductile Iron and probably more besides.
                                    BobH
