re seating a ball??
re seating a ball??
Home Forums Beginners questions re seating a ball??
  • #9393
    Terry Chapman 2
      @terrychapman2
      Terry Chapman 2
        @terrychapman2
        Hi,Ive got water coming into my oil box and had a look look at the one way valve and it seems the balls not sealing?
        Whats the best way to re seat bearing (excuse the pun) its about 1/8" diameter.
        Its off my 1" Minnie.
        Thanks
        #378686
        RevStew
          @revstew
          Brass pin punch onto the ball and a sharp tap with a hammer works for me.
          #378688
          Terry Chapman 2
            @terrychapman2
            Posted by RevStew on 01/11/2018 14:39:25:
            Thanks,Ill give that a go?
            #378689
            HOWARDT
              @howardt
              Preferably use a new ball after re-seating as per RevStew.
              #378694
              mechman48
                @mechman48
                +1 … always seems to be the preferred method.
                George.
                #378707
                Dalboy
                  @dalboy
                  Another way to do this is to solder a new ball onto a small shaft and apply very fine grinding past or burnishing cream and lap it as you would a car valve then replace the old ball with a new one after cleaning out
                  #378711
                  Nigel Bennett
                    @nigelbennett69913
                    If the seat's not in too bad nick, you could also try a nitrile ball – Polly sell them. I've had a lot of good results with them.
                    #378733
                    Jon Lawes
                      @jonlawes51698
                      I'm tempted to try a nitrile ball in my water pump if only because it might help with the quality of my workmanship so far…
                      #379106
                      Terry Chapman 2
                        @terrychapman2
                        I done the 'Tap' job and is all fine now thanks
                        #379499
                        RevStew
                          @revstew
                          I've used that technique on hydraulic systems running up to 720bar. Now here's a thing. I wonder if such an arrangement would be more likely to leak with more pressure, or less pressure?! Anyone care to hazard a guess?
