rdg quick change tool myford super 7
Home Forums Workshop Tools and Tooling rdg quick change tool myford super 7
  • #323287
    lug lord
      @luglord
      Re these any good i bought one a while ago from somewhere else for a mini lathe and it was no good
      thanks ian
      #18715
      lug lord
        @luglord
        #323294
        David Standing 1
          @davidstanding1
          I think you will have to expand on 'it was no good'
          Why was it no good?
          #323330
          lug lord
            @luglord
            the one i bought for my mini lathe 7 x14 chinese one was not from rdg and the tools did not fit in the holder had to file them down and they was not very secure, had a lot of movement nothing seemed to sit flush . I i was turning 8mm stainless 316 so probably pushing the mini lathe to its limits .Hence why i sold it now and have a much larger myford super 7 which i love to use
            #323338
            NIGEL pearson 1
              @nigelpearson1
              i have about 12 from RDG tools and they all fit my myford dickson tool post with out any problems. also on my myford ml7r
              #323341
              Samsaranda
                @samsaranda
                Recently purchased an RDG quick change toolpost which is made to fit Myford , fitted it to my Warco BV 20 lathe, not strait forward as the mounting hole is 11.2 MM and needed to fit 12 MM on my lathe, to cut a long story short removing the 0.8 MM from the mounting location was a challenge as the mounting block is hardened ground alloy steel. Objective was achieved and the toolpost fits on my lathe a treat, to say I am pleased with it is an understatement, what a joy to use, all my 12 MM tooling fits the tool holders. I would endorse the RDG product and as usual no connection with company only a very satisfied customer.
                Ian Skeldon 2
                  @ianskeldon2
                  I bought the RDG dickson type QCTP for the boxford, my lathe is a Chester DB10 so I had to modify the compound slide, now fitted I love it, I was worried about repeat accuracy but it seems to be really good, wouldn't be without it now.
