Ramdon thought
Ramdon thought
Home › Forums › General Questions › Ramdon thought
  • #316048
    Piero Franchi
      @pierofranchi37209
      When using a surface grinder, surly the tollerance is lost from the start for the grind to the end of each pass as the stone its self must wear down a tad no ???
      Edited By Piero Franchi on 09/09/2017 09:20:54
      #25487
      Piero Franchi
        @pierofranchi37209
        Surface grinder
        #316049
          Posted by Piero Franchi on 09/09/2017 09:20:10:
          … the stone its self must wear down a tad no ???
          Yes
          … But tads are very small
          Piero Franchi
            @pierofranchi37209
            Only I have not long ago bought my self a used Clarkson tool and cutter grinder,
            my minds was running wild with what other jobs I can do with it, and although I know its not a true surface grinder in the sence of its not build specifically for that,
            I am sure I might be able to use it on a less important job.
            that just got me thinking onto how surface grinders work and how the stone wearing out must affect the tolerance
            #316057
            Hopper
              @hopper
              You make your final cut a very light one so that wear on the stone is a minimal number of tads over the course of the full surface.
              #316128
              mark costello 1
                @markcostello1
                Surface grinders benefit from a "spring" pass also.
                #316130
                Anonymous
                  The phrase, to make it look like one knows what one is talking about, is "spark out" pass. smile
