Question Re Camlock Chuck Fixings
Home › Forums › Manual machine tools › Question Re Camlock Chuck Fixings
  • #14545
    Colin Heseltine
      @colinheseltine48622
      #596205
      Colin Heseltine
        I have recently swapped out my Colchester Student lathe with L0 chuck fixing and replaced it with a Colchester Triumph 2000 which has D1-6 chuck mount on the spindle. I have the standard 12" 4 jaw, and 8" 3 jaw chucks as well as a Burnerd Multisize chuck.
        I had a 6" Burnerd GripTru chuck on the Student which has a backplate with the L0 fixing. I wish to be able to use this on the new lathe and so need to replace the L0 backplate with a D1-6 camlock backplate. I have been looking on Ebay and there are quite a few D1-6 camlock backplates available for chucks around the 6" to 8" diameter range but they all appear to only have 3 camlock pins rather that the full 6. Can a 3 pin fixed chuck work as safely as a 6 pin mounted one? The only 6 pin one I can see on the market at a reasonable price is that marketed by RDG, although that ideally needs turning down from the supplied 200mm to be closer to the required 6" diameter.
        Any thoughts,
        Thanks,
        Colin
        #596207
        Chris Evans 6
          @chrisevans6
          Are the advertised back plates just showing a generic picture of a cam lock and not the actual article ?
          #596213
          Dave S
            @daves59043
            IIRC the late Sir John Stevenson of this parish used to run D1-6 with only 3 pins in it.
            The pins pull the taper together. 3 is most likely sufficient for most uses.
            Somewhere on the internet (might be the home shop machinist bbs site) there is a long discussion about this and how 3 pins are plenty enough based on the strength of them.
            Dave S
              @daves59043
              A small amount of poking later : **LINK**
              John was running D1-5 not 6, but the principal is the same
              Pete Rimmer
                @peterimmer30576
                My 8" 3 jaw is held by three D1-3 pins. I see no problem with holding the same size chuck with 3 of the much stronger D1-6 pins.
                #596219
                Henry Brown
                  @henrybrown95529
                  I use a 250mm ( 9.75" ) on 3 x D1-4 pegs on my Warco GH 1332 without issue so you should be fine.
                  Edited By Henry Brown on 28/04/2022 17:49:46
                  #596220
                  Roger Williams 2
                    @rogerwilliams2
                    Hello, I purchased my D16 backplate from Chronos , excellent quality and 6 pins , for an E40 collet chuck adaption. Good service too.
                    #597361
                    Colin Heseltine
                      Thanks for the responses. I had hoped to put my 6" Griptru chuck onto the D1-6 backplate. When I tried to remove what I thought was the L0 backplate, I very quickly found that it was an integral part of the chuck. Oh well, that is another chuck I need to try and sell along with my Burnerd Multisize collet chuck.
                      Thanks,
                      Colin
                      #597376
                      Pete Rimmer
                        @peterimmer30576
                        L0 chucks sell quite readily. I don't think you'll struggle with that.
