So here’s a puzzle. I want to d
rive a quartz clock movement from an Arduino instead of its internal electronics. Taking it apart and putting flyleads onto the coil needs a steady hand, but successfully completed. The coil has a resistance of 250 ohms, so I added 150 ohms in series to get within the drive capability and connected across 2 pins of the arduino. Sending alternating polarity pulses should drive the movement, and at 10ms it did, but BACKWARDS. Changing the circuit to what I’ve used before, 470 ohms resistor, coil, 470uF capacitor in series connected to one pin and ground it drives the correct way. Anyone care to speculate what is going on?
