problem with posting replies?
Home › Forums › General Questions › problem with posting replies?
  • #304863
    Phil Whitley
      @philwhitley94135
      Just hand crafted a long and complex reply to a post, which I have luckily copied to clipboard, but cant get it to post, all I get is a blank white page with
      "Sorry, the page you requested cannot be displayed at this time, please try later"
      Do we have a problem Houston?
      PHIL.
      #25336
      Phil Whitley
        @philwhitley94135
        for moderators!!
        #304864
          Try splitting it in two, may just be too long. Obviously as you have made this posting things can't be too bad.
          Also by complex do you mean you have included tables etc in it which may be affecting things?
          J
          #304865
          Phil Whitley
            @philwhitley94135
            Thanks Jason, no, no tables, just text, will try that! bit obvious when you think about this still working…………………………………………………….DOH!
            Phil
            #304868
            Phil Whitley
              @philwhitley94135
              Is there a time limit between postings?, if not I have a problem with the text in the second half, furst half went up immediately, second half still won't post
              #304869
                Post it in a second reply and I'll see if I can move it, you should have about 10 mins to go back and edit the first reply
                #304873
                  Has it got an image in it?
                  Sometimes if you post an image it won't go live, and even if you delete it it still won't appear.
                  Phil Whitley
                    @philwhitley94135
                    Found it! It had picked up on one instance of the initials "EU" put a dotted underline under it, which returned " European Union" on mouseover, when I removed and retyped, it posted! Thanks for your help!
                    Phil
