Press fitting, heat fitting, freeze fitting?
Home › Forums › Beginners questions › Press fitting, heat fitting, freeze fitting?
  • #343891
    Simon Haynes
      @simonhaynes36024
      Hello all
      I need to get disks fitted near one end of lengths of extruded aluminium tubing (6082). 2", 2.25" and 3.5" diameters. So as to create bases.
      I have been quoted for welding (too expensive). Does anyone have a sense of what is possible and what the most cost effective solution could be.
      Thanks in advance.
      #9108
      Simon Haynes
        @simonhaynes36024
        Very light engineering
        #343936
        Brian H
          @brianh50089
          Are the disks just flat or could they have step to locate them securely? Also, is there any load or heat on them in use?
          If they are just a stand with no forces involved then either a press fit or heat shrink or adhesive may be satisfactory.
          #343942
          David George 1
            @davidgeorge1
            Hi Simon have you got a drawing, what are they for and what sort of forces are involved. If they are only light duty and don't carry much load I would turn a small shoulder and shrink fit but if have a large load you can drill and tap on the joint and screw a grub screw in to secure in three or four places around the diamiter.
            David
            #343948
            Speedy Builder5
              @speedybuilder5
              And how thick are the discs ? If they are not thick enough for a glued joint then perhaps "LUMIWELD" would work
              BobH
              #343957
              Simon Haynes
                @simonhaynes36024
                Thanks to all of you. The disks will be 1.5-2mm and it’s a very light duty application. I will explore adhesives via Permabond. Next stop Lumiweld – that’ s not a system I was aware of. Thank you again.
