prazi SD300 spindle removal question
Home › Forums › Manual machine tools › prazi SD300 spindle removal question
  • #533688
    Henry Rancourt
      @henryrancourt22682
      The manual shows two snap rings that rest against shim washers that rest against the inner bearing faces. Based on that it seems that the rear bearing must be a sliding fit on the spindle so it can be removed before tapping the spindle out towards the tailstock. Is that a valid assessment?
      #14197
      Henry Rancourt
        @henryrancourt22682
        #533707
        DiogenesII
          @diogenesii
          It is – this chap (to whom I have no connection) posted a record of removal / replacement for posterity here;
          Bazmonaut MD65 Spindle Bearing Replacement
          #533727
          Henry Rancourt
            @henryrancourt22682
            I had read the bazmonaut spindle replacement but missed the sliding bearing bit.
            #533743
            Roger B
              @rogerb61624
              The rear bearing is a sliding fit on the shaft so that the end play can be adjusted with the two nuts. There is no need to remove the rear bearing before taping/pulling the spindle out.
              Why do you feel that you need to replace the bearings?
