Pratt Burnerd 4 jaw Chuck jaw alignment
Home Forums Workshop Tools and Tooling Pratt Burnerd 4 jaw Chuck jaw alignment
Viewing 19 posts - 26 through 44 (of 44 total)
  • #434309
    lfoggy
      @lfoggy
      Quick 'back of the envelope' suggests that at 1000rpm there will be a 50N radial force on each jaw, i.e. 5Kg . Cutting forces will generally be in the same direction as well. Maybe a bad idea though ! I'm sure a rummage through my scrap box will unearth a suitable ring against which to clamp the jaws.
      lfoggy
        @lfoggy
        Posted by Pete Rimmer on 22/10/2019 00:43:31:
        I have I think 3 sets of 4-jaw chuck jaws of unknown provenance. Put up some basic dims of your jaws and I'll check the ones I have. In the unlikely event that one of those set match, you can have it.
        Very kind offer. Let me try the grinding first but if that goes pear shaped then I may be in contact !
        #434322
        old mart
          @oldmart
          Grinding this type of jaw would be best done individually in a vise. There still needs to be a slope on the jaws, and it would be best to try reducing the slope from the present 0.1mm to 0.05mm initially and then find out if that solves the problem.
          The reason for drilling the jaws is because they have to be tensioned inwards while leaving the inside edge free for the grinding wheel, a near impossibility with four independent jaws, which is why nobody grinds them in situ.
          I have a 6" Toolmex four jaw independent at the museum, and will try measuring the jaws to see what slope they have.
          #434323
          Pete Rimmer
            @peterimmer30576
            If you're going to grind then then turn a ring concentric on OD and ID and clamp it in the jaws on the ring's ID. Clock the ring in the 4 locations directly over each jaw and adjust until all read the same then you can grind them very gently at slow rpm.
            Use the biggest grinding wheel you can sensibly fit in the hole so that when you dress it true you get the maximum amount of grinding before the wear on the grinding wheel reaches full span. You might do well to make a roughing pass, dress the wheel then take a very light finishing pass.
            #434327
            old mart
              @oldmart
              If you do that, you are tensioning the jaws outwards, which defeats the whole object of tensioning them in the first place. They must be tensioned in the same direction as they are to be used.
              #434420
              Hopper
                @hopper
                Normally when cylindrical grinding, the job is rotated at more like 50rpm or even less.
                Yes the jaws would need to be set up so the outer tips of the jaws are tensioned outwards, as they are when clamping onto a job. You could still do this with a "four leaf clover" plate and then as you say set the jaws concentric with a DTI. Althoug, perfect concentricity is not critical on an independent jawed chuck. Few thou extra off one jaw is not going to make any difference when each jaw is set up in used independent of the other.
                If you had access to a surface grinder it would be ideal to set the jaws up on the table and knock that few thou off that way.
                I've reground several Myford (PB and Crown) chucks with clover leaf plates, ground them parallel with a die grinder in the toolpost, and they are still working well. Maybe in another 50 years they will start to bellmouth again but I won't be around to worry about that.
                Whichever way you go with it, the jaws have got to end up better than they are at the moment. You could almost dress four thou off one end with a diamond file by hand and be better off than you are now. Almost.
                Edited By Hopper on 23/10/2019 11:32:32
                #434422
                Pete Rimmer
                  @peterimmer30576
                  You should be able to grind an essentially brand new chuck without fear of the jaws cocking. If they do cock then they wouldn't be able to clamp anything effectively inside and outside without suffering problems.
                  #434451
                  lfoggy
                    @lfoggy
                    The jaws are a firm sliding fit in the slots with no discernible play so I am hoping that they will remain aligned during grinding.
                    I don't have a surface grinder but another option is to use a cupped diamond wheel in the milling machine with the jaws held in the milling chuck. I have used this setup to grind small amounts off hardened components in the past and it has worked.
                    I will try to get this sorted over the weekend and will post an account of success or failure….
                    #434466
                    old mart
                      @oldmart
                      Making a four leaf clover tensioner seems like so much bother, and it only fits one size of jaw. That's why I drilled the jaws with a carbide drill and use any of several rings of different sizes bought cheaply on ebay. The rings are primarily for use with the serrated jaw chuck which requires tensioning every time the jaws are bored.
                      #434525
                      Howard Lewis
                        @howardlewis46836
                        Somewhere, I have some new chuck jaws for a 160mm chuck, still in original wrappings. Think that they are for a
                        P B, but can't remember if they are for a 3 or 4 jaw. Would need to go and find them!
                        #434535
                        Pete Rimmer
                          @peterimmer30576
                          I just checked, my spare jaws are PB but they are for a smaller 4-jaw having a .200 slot and 8tpi screws. The jaws in my 8" 4-jaws and a bit bigger with coarser screws.
                          #434547
                          Hopper
                            @hopper
                            You can avoid the fiddly job of making a clover leaf plate and use four pieces of flat bar to put between the jaws and then tighten them down on. This video shows the concept, albeit on a three jaw, better than I can explain in words. The hacksaw slot and hole in each piece would be good on teh four-jaw as it would allow fine adjustment of each jaw to get them all concentric before starting. A suitable disc held in the tailstock might also help set the jaws concentric to start with.
                            I would use some thing like this even on a new chuck because there is going to be that tiny bit of working clearance between the jaws and the guides in the chuck body, which will allow a certain amount of movement. Also the slack between the thread on the jaw and the thread on the chuck key barrel will allow movement. Best to have everything locked down dead tight for the best possible job.
                            Edited By Hopper on 24/10/2019 12:30:19
                            Edited By Hopper on 24/10/2019 12:33:28
                            #434582
                            old mart
                              @oldmart
                              I set up one of the jaws of my Toolmex light 6" chuck, which is in almost new condition in a similar fashion except for having a cylindrical surface for the tip to bear against. The ground surface if the jaw tip is not flat, it has a radius. The jaw is exactly 16mm wide, so I used the shank of a 16mm endmill. The measured slope is much less than yours at 0.0005", 0.0127mm over approximately 40% of the length of your jaw.
                              #434954
                              lfoggy
                                @lfoggy
                                I have now ground the chuck jaws using the setup below.
                                Grinding wheel rotating at 5000rpm (too low I know) and lathe chuck rotating at 1000rpm. Removed 0.02mm at a time. Lots of sparks but otherwise uneventful. The finish on the jaws was very good.
                                The chuck is new and the jaws are a very firm fit in the slots with no discernible movement so I don't think much 'cocking' has taken place although i fully acknowledge the logic of grinding them tensioned in the closed direction.
                                Testing the newly ground jaws as below shows that the clamping face of the jaws is at right angles to the slots to within <0.01mm as below.
                                I know some people suggested a slight taper on the jaws which is logical but hard to achieve so I just ground them straight.
                                I can now hold a test bar securely and accurately in the chuck – much better than before. I'm very pleased with the result and was surprised how easy this was to do.
                                #434957
                                  Nicely done, Sir yes
                                  John Baron
                                    @johnbaron31275
                                    Posted by lfoggy on 20/10/2019 20:37:26:
                                    I've recently acquired an 8 inch Pratt Burnerd 4 jaw independent chuck. It is stamped 'Made in England' and I think it was manufactured in the 80s. It seems to be unused or virtually unused as there are no marks on the chuck whatsoever and the D1-3 camlock fitting shows no signs of ever having been attached. The jaws have a perfect ground finish and are unmarked with no detectable play in their slots. When I fitted the chuck to my lathe to test trueness I found the chuck body to run true to <0.01 runout.both on the periphery and on the face. The clamping surface of the jaws however are not parallel. They are the opposite of 'bell- mouthed' as in the pic below. The taper is consistent on all four jaws. This may not matter too much for many applications but is definitely apparent when trying to grip a long and accurately machined workpiece.
                                    What is the explanation for this? Were the jaws deliberately given a taper to accommodate wear or do I just have a badly made chuck? I am suspecting the latter.
                                    I do reaslise that this taper would be easy to correct by the in situ grinding of the chuck jaws and I may well resort to this.
                                    Hi Ifoggy,
                                    I have recently had a similar issue ! But in my case the jaws all had different amounts of taper to the back. I've simply reground mine parallel. However I've also recently discovered that PB deliberately grind the jaws with a 2 to 3 thou backwards taper. Apparently to allow for grinding tolerances in the guides.
                                    #476496
                                    John Baron
                                      @johnbaron31275
                                      Opps, Sorry wrong thread !
                                      #476515
                                      Martin Kyte
                                        @martinkyte99762
                                        Does anyone know how 4 jaw independent chuck jaws were originally ground. I can't believe they were ground in the chuck body. There must be a reference surface to orient them in the grinding jig. I'm thinking the rebate as the reference myself. Just curiosity really.
                                        regards Martin
                                        #476522
                                        KWIL
                                          @kwil
                                          Nobody has mentioned it yet, but Rotagrip are experts in all things to do with chucks, helpful supplier.
