Potty overcrank engine
Home › Forums › Drawing Errors and Corrections › Potty overcrank engine
  • #38751
    Eric Cox
      @ericcox50497
      #82284
      Eric Cox
        @ericcox50497
        ME 4420 p.39
        Stop valve part 52 is shown as a general arrangement only without dimensions.
        ME 4421 p116/117
        Straight link part 62, the text states 3mm Dia. x 12mm long. Should this be 3mm Dia. x 20mm long.
        As an alternative method just use 3mm Dia. rod
        Bracket part 60. How deep should the 3mm wide slots in the bearing housing be.
        What is the dimension for the centre line of the bearing housing be in relation to the bracket.
        As an alternative method for the bearing housing, drill each end of the bar 6mm x 15mm deep then bore each end to take the bearing. That way you do away with the Spacer part 67
        Governor, where does the return spring fit.
        #82287
          The fully dimensioned stop valve parts are in 4421
          I make the overall length 19mm 4+14+ (0.5×2) So text should read turm 3mmx 15mm long as thats the length of square section required
          Yes it could be made from 3mm stock
          Slots in bearing bracket are 2.5mm not 3mm and ctrs are given as 4mm, slots go right through as they are for fixing bolts.
          Centreline is 29mm from left edge. the inner edge of the L/H bearing is in line with the shaped cut out so 22-6=16. 16/2 =8. 8+21r=29.
          Picture 90 shows the spring in position
          J
          Edited By JasonB on 17/01/2012 11:07:38
          Edited By JasonB on 17/01/2012 11:09:34
          #82288
          Eric Cox
            @ericcox50497
            I was referring to the depth of the slots in the bearing housing that the bracket is silver soldered to.
            #82290
              Thats upto the builder really as long as you end up with the flat part 84mm from the edge of the bearing housing thats what matters even then you have a bit of leeway due to the slotted fixings. The groove is only to help keep things in place while soldering.
              So if you cut your plate to 85mm the slot will need to be 1mm deep, cut it 86mm and have a 2mm deep slot. Remember to set the centre of teh 21 & 29mm arcs down from the top of your plate by whatever length you go for.
              J
              #82303
              Stewart Hart
                @stewarthart90345
                Hi Eric
                Jason is correct with his answer (thanks Jason)
                Eric are you planning on building an engine,
                With a bit of luck I should have the engine at the Northern Model Exhibition and the Traford Centre Manchester in early March on the South Cheshire ME society stand
                Stew
                #82316
                Sub Mandrel
                  @submandrel
                  Hi Stew,
                  Really silly off-topic question, but your ‘avatar’ seems to be the same picture as the ghastly logo on the Buck Hickman lorries? Is it some sort of mutant Easter Island head (I understand they had topknots and eyes on the originals)?
                  Again sorry for going OT but this question has been bugging me for years (Buck Hickman, not your avatar…)
                  Stewart Hart
                    @stewarthart90345
                    Hi Neil
                    My avater is an Easter Island Moai as you guesed.
                    We had an holiday in Chile a few years back and visited Easter Island:- when first built they had topknots and eyes made from white coral, then they started to fall out with each other and distroy the other clans Moai (like distroying your mojo). My avatar moai is one they recontructed, using origonal bits with new eyes, loctited in place.
                    The best Moai is in the British Musium the Victorians were not only great at building Engines they were good at pinching stuff as well.
                    Cheers
                    Stew
                    #82469
                    Sub Mandrel
                      @submandrel
                      > They were good at pinching stuff as well
                      Not as good as the Elizabethans!
                      What i still don’t understand is why the Buck Hickman lorries have that strange psychadelic version on their lorries!
