Potty ME4413
Potty ME4413
Home › Forums › Beginners questions › Potty ME4413
  • #75376
    Eric Cox
      @ericcox50497
      In ME4413, page 443 drawing 4 there appears to be an angular dimension on the cylinder block section A-A. It looks like 150t, what is it.
      #5669
      Eric Cox
        @ericcox50497
        #75380
        KWIL
          @kwil
          If you look at the other dimensions of the block and cylinder, the centerline of the cylinder is 20mm from the bottom face, the cylinder diameter overall is 26mm and hence the top edge of the cylinder is 20 +13 = 33mm. The overall height is 48mm, subtract 33mm remainder is 15mm so 150t should read 15.0 !!
          Edited By KWIL on 25/09/2011 11:25:27
          #75383
            No it should read 15 degrees, another cast of not checking the scanned in image, here is a snip from Stew’s original drawing
            Sorry its not that clear but you can definatly see its 15 degrees, its a lot clearer if you look in my album, the mag software is blowing it up too much
            J
            Edited By JasonB on 25/09/2011 12:01:22
            #75402
            Stewart Hart
              @stewarthart90345
              Jason has got it correct it should be 15 deg, I did notice in my copy of the mag that it was a bit unclear.
              Any other ? please don’t hesitate to ask, or send me a PM
              Stew
