Portass dreadnought restoration
Home › Forums › Manual machine tools › Portass dreadnought restoration
  • #534261
    Carl Dorling
      @carldorling51660
      Hi, I have discovered the bull wheel is past repair does anyone know what the teeth count is .
      #14204
      Carl Dorling
        @carldorling51660
        Bull wheel
        #534273
        Mick Dobson
          @mickdobson
          Hi Carl,
          I'll have a look tomorrow after work.
          Regards, Mick
          #534433
          Mick Dobson
            @mickdobson
            Hello Carl;
            The bull wheel has 75 teeth.
            Regards, Mick
            #534435
            Carl Dorling
              @carldorling51660
              Thank you Mick , and would I correct in saying that it’s 16DP .
              #534438
              Brian Wood
                @brianwood45127
                My apologies Carl for inadvertently leading you astray. Clearly the Dreadnought is a very different lathe to the ordinary Portass versions which were I believe Myford clones.
                Regards Brian.
                #534441
                Carl Dorling
                  @carldorling51660
                  Good evening Brian, no problem I’m learning all the time.
                  #534739
                  Mick Dobson
                    @mickdobson
                    Hello Carl,
                    For your question regarding the bull wheel. Yes it is 16DP, same as the change wheels.
                    Regards, Mick
                    #539352
                    Carl Dorling
                      @carldorling51660
                      Hi All, I have had a good look at the lathe and noticed more differences to all others I can find pictures of, it has a short rack and a different apron to others that and the headstock design plus the number 5 stamped on all parts leads me to believe this was a very early example so possibly quite a rare lathe definitely worth saving.
