Polly II
Polly II
Home › Forums › Locomotives › Polly II
  • #1598
    michael cole
      @michaelcole91146
      Buying a older Polly
      #288905
      michael cole
        @michaelcole91146
        Next week i am going to have a look at a couple of Polly II with the intention of buying one.
        Is there anything I should be looking for . Are there any weak points or what is likely to wear and need replacement?
        #288924
        BC Prof
          @bcprof
          I purchased a Polly 3 from a dealer in May last year. New hydraulic and steam tests. Ran fine with no horrible noises just a leaking regulator . Taking it apart for a much needed re paint revealed over 1mm play in the coupling rod bushes and some play in the eccentrics. Typical wear points .All easy to fix at no great explense . Don't rely on purchasing new spare parts to replace those that need attention . The prices are !!!!!
          Brian C
          #289059
          michael cole
            @michaelcole91146
            thanks Brian, i also had a look at you postings about CE marking on Polly boilers.
          Home › Forums › Locomotives › Topics
