Please identify
Please identify
Home › Forums › Beginners questions › Please identify
  • #99843
    Takeaway
      @takeaway
      I have had these two identical brassy things for a long time and have often wondered what their purpose was. If I was forced to guess I would say they might – only might – be a pair of steam boiler injectors. However, there are a lot of very clever folk hereabouts and I’m hopeful that someone can identify their purpose with a little more certainty than my wild guess.
      I’ll just point out the following:-
      The large end and small end are externally threaded (very fine) and both look like the same thread pitch.
      The end face on the largest diameter part carries a circular groove semi spherical in cross section (“O” ring groove?). The rest of the face inside the groove is tapered inwardly approx 2-3 degrees towards the central hole.
      I originally intended chopping them up for projects but now I can’t bring myself to ruin such nicely machined objects. Maybe I’ll just polish them up and stick a couple of candles in ‘em!
      Stuart
      Here they are:
      Takeaway
        @takeaway
        Pair of mystery brass objects.
        #99848
        russell
          @russell
          Sorry, but that link wants me to set myself up as a blogger…
          I love a mystery but not that much.
          #99849
          Takeaway
            @takeaway
            Sorry Russell – these links used to work but I think Google has been tinkering again. What makes it worse is that this forum will not allow the post to be edited. I will just have to find a work round and post again with proper acess to the pics.
            #99855
            Takeaway
              @takeaway
              Apologies for dodgy link in original post re: Mystery brassy things. Try this one instead.
              Stuart
              #99856
              wheeltapper
                @wheeltapper
                It looks to me like someone made some fancy candlesticks as an experiment .
                AFAIK not anything to do with injectors or anything of that ilk.
                the threads on each end are a mystery tho.
                Roy
                Edited By wheeltapper on 02/10/2012 14:20:07
                #99857
                Clive Hartland
                  @clivehartland94829
                  My first thought is that it is off a Fire Hose and goes between the nozzle and the hose connector ?
                  clive
                  #99869
                  wheeltapper
                    @wheeltapper
                    That did occur to me Clive but how much water would you get through a 9.5mm hole?
                    Roy.
                    #99879
                    Stovepipe
                      @stovepipe
                      Chess pieces ?
                      Dennis
                      #99880
                      Bazyle
                        @bazyle
                        Looks like a bit of a steam valve operating piston for a realtively modern hence complex engne.
                        #99916
                        jason udall
                          @jasonudall57142
                          Looks like some of the "sample" parts made at trade shows show how quick and nice the ZYX machine is…got a few like it myself….
                          #99917
                          Terryd
                            @terryd72465
                            Hi,
                            They remind me of gas light fittings,
                            Terry
                            #100012
                            Takeaway
                              @takeaway
                              Wise guys aay? Well, in a paragraph let me explain their function —— oh blast, run out of ink!
