Please help with my Turner lathe
Home › Forums › Workshop Tools and Tooling › Please help with my Turner lathe
  • #536878
    Angela Jarman
      @angelajarman60437
      Dear members
      I've joined the forum to send a request out for an engineer who may be able to help.
      I'm a glass artist in Hertfordshire with a Turner lathe that I bought years ago from Stourbridge (when a glass factory was selling off lots of its equipment). It's in good working order (3 phase) but 2 things make it un-use able for me – it's spindle is imperial, and I'm unable to buy diamond wheels to fit it (don't want the faff of bushes), – it's multi speed with a belt drive which is an absolute bugger to change. My dream is that I can get the spindle turned down to metric size, and get rid of the belt drive.
      Apologies for my ramblings but I'm hoping somebody might be able to help, or put me in touch with an engineer who can. Obviously I'll pay.
      Many thanks AJ
      #20220
      Angela Jarman
        @angelajarman60437
        Modifications needed.
        #536893
        John Haine
          @johnhaine32865
          What size is the imperial spindle and what metric size would it need to me? If it's made like metal lathes it is probably hardened so difficult to turn but could be possible to make an adapter. What speed does the spindle go? It could be hard to just get rid of the belt drive but if the motor is 3 phase a variable frequency drive could be the best option.
          Can you post some photos? There are instructions here somewhere. Where are you in Hertfordshire?
          #536894
          Nigel Graham 2
            @nigelgraham2
            I can't help with modifying the spindle but can suggest buying a 3ph speed controller. These are now easily available, but most we see advertised to model-engineers are designed primarily to run 3ph motors from 1ph domestic supplies. Nevertheless, if you have a 3ph mains anyway, I'd have thought the same suppliers can provide a speed-control alone. Worth enquiring.
            However… the motor still needs to run fast, at or fairly near its normal maximum. My inverters have their "red zones" at the low, not high, end of the scale. I am not certain why. It might only be for cooling and one or two people have reported replacing or augmenting the motor's own fan with a separately-driven one.
            I am guessing though that if this lathe is actually a special type of glass-cutting grinder, it needs high spindle speeds?
            For that reason, it would be best and anyway is by far the easiest solution mechanically, to keep the belt drive even if you leave it almost always on one, optimum setting. Changing the electrics is much simpler! Changing a belt drive can involve a lot of machining.
            Regarding machining the spindle, that is best done on the lathe itself, if only a simple diameter reduction, if the lathe has conventional screw-controlled slides. It may mean fitting a temporary tool-post. If it needs a nose-thread re-cutting and this lathe has no facilities for that, you would have no alternative to having it machined on someone else's lathe.
            As your enquiry suggests this is a highly-specialised machine-tool, it might help if you can supply photos (I think you have to create an album).
            #536895
            Grindstone Cowboy
              @grindstonecowboy
