David,
I've had a look on both the pack, and the website – only described as "plastic".
The website states "Plastic shim performs the same function as metal shim, but has additional uses as a seal and as a barrier to prevent corrosion between dissimilar materials".
Although RS say that it is their own make, the PAR group describes "Plastic" shim thus:
Material Specification 'A
These specifications applies to thickness from .001” to .015” as detailed and are produced colour coded from polyester films ('Melinex', 'Mylar', 'Hostaphan'
to meet the particular demands of the engineering, automotive, electrical and electronic industries. Polyester materials are remarkably tough with very high compressive and dielectric strengths, very low water absorption, and excellent dimensional stability over a wide range of temperatures and good resistance to most chemicals, ozone, direct sunlight etc.
So I rather suspect the RS stuff may be Polyester
Does that modify your thoughts?
MTIA,
Peter G. Shaw
