Place to buy sanding belts / discs.
Home › Forums › General Questions › Place to buy sanding belts / discs.
  • #150899
    Chris123
      @chris123
      Where the best internet place to buy sanding discs (adhesive) and belts?
      Thanks,
      #23276
      Chris123
        @chris123
        #150936
        Brian Wood
          @brianwood45127
          Hello Chris,
          Why not do what I just did and Google 'sanding belts' The choice is enormous, as for best, how do you define that; quality, price, make, delivery cost or what?
          As with all things, so much depends on what you are looking for and I for one am not a clairvoyant.
          I hope you find what you are looking for
          #150938
            I get my woodworking ones from CSM and metalworking from MSC
            #150946
            MichaelR
              @michaelr
              Screwfix may have what you need. Here
              #150952
              Chris123
                @chris123
                Hi, I meant for finer grades. I'm after 800-400.
                Struggling a bit!
                #150953
                Dennis
                  @dennis66942
                  Try motor car paint suppliers.
                  #150954
                    The MSC link I gave above do sticky disc in 400, 500 & 600 and the CSM do p400 though does depend what dia you need
                    #150955
                    Chris123
                      @chris123
                      Just found abtec4abrasives.com!
                      most likely sorted now thanks.
                      #150956
                      Chris123
                        @chris123
                        Most have missed the ones on MSC then.
                        Thanks.
                        #150957
                        Ian Welford
                          @ianwelford58739
                          try RJ Taylor for Abranet, truly excellent stuff on wood and metal. I've got 600 grit and micromesh goes upto 12,000 grit but got that from a guy at Woodfest.
                          Regards ian
                          #150959
                          Ian Welford
                            @ianwelford58739
                            oops should have read you want self adhesve- the stuff I recommended is velcro!blush
                            Ian
