Phone Phreaking
Phone Phreaking
Home Forums Clocks and Scientific Instruments Phone Phreaking
  • #813124
      I have a distant memory of reading a good article about this in one of the ‘Sunday Supplements’
      Some of the forum’s telephone engineers might like to elaborate
      Hugh Stewart-Smith 1
        @hughstewart-smith1
        Whoa! That takes me back to the mid-60’s when we found a way of getting free calls from ‘phone boxes.
        By tapping out the number on the bar on the telephone cradle you could get connected for free. You had to tap the number with a pause between numbers and the numbers ‘0’ and ‘9’ could be dialled.
        Does that ring any bells? – although it used to ring a few numbers!
        We didn’t think ourselves as ‘phreaks’ though.
        Hugh        Amadeal Ltd
        #813162
        duncan webster 1
          @duncanwebster1
          On the old dial phones which also had letters against the numbers, if you dialled GULO6 first, you got free calls from a phone box. Not that I ever did you understand
          #813163
          John Haine
            @johnhaine32865
            Old phone boxes used to have a coin mech that generated 10pps “dial pulses” to indicate the coin type.  In order to discriminate between these and normal pulses the line was reversed in “quiescent” mode and series diodes used in the payphone to decide which of the dial or mech was in circuit.  Once a valid coin had been signalled the exchange would reverse the line back to normal to permit dialling and speech.  I knew of at least one payphone in a university hall of residence where enterprising engineers had shorted out the dial diode so the coin value could be “dialed in”.  Ah, those were the days before hacking became a thing.  I recall that Plessey had a “consulting vandal” they used to try to break payphones too.
            #813190
            Robert Atkinson 2
              @robertatkinson2
              When making calls from work most extensions would have international and premium numbers blocked. One way around that was to use the handset on the Fax machine…
