I've never had the slightest difficulty making rectangles and even odd shapes in PCB materials by simply sawing to shape . All sorts of setups are possible from hand power piercing saw to precision machine set ups with a slitting saw .
Before much scale model railway material became available commercially many people made track sleepers from PCB materials and used a Dremel type cutter through a slot in a piece of plywood . Simple fence meant PCB sleepers could be cut in their hundreds at average cutting time of a couple of seconds .
Never any problem with the copper stripping off due to cutting as long as fine blades used .
Purely as a matter of interest I used to make parts for prototype , single use and small production runs of special purpose instrumentation by CNC milling out a complete kit from PCB material . The one fret ended up with printed circuits , contacts , connectors , mechanical parts and spacers all ready to use . One even had a timing wheel and matching masks cut in .
Michael Williams .
Edited By MICHAEL WILLIAMS on 21/11/2012 16:04:39
