Parting off query
Parting off query
Home Forums General Questions Parting off query
  • #409536
    Plasma
      @plasma
      Hi all, when parting off the 2 inch brass bar for my door knob bezel the face of the bar ended up concave with a matching convex face on the parted off disc.
      Suggestions on a post card please…..
      #26611
      Plasma
        @plasma
        Concave face for some reason
        #409537
          If it is an HSS blade then make sure it is ground dead square across the end. If insert then use a neutral one which will be square across the end.
          In both cases make sure the tool is at perfect right angles to the lathe axis.
          I'm sure someone will be along to tell you to use a rear tool post toodevil
          #409539
          Samsaranda
            @samsaranda
            Make sure the carriage is locked down as solid as you can get it.
            Dave W
            #409540
            Plasma
              @plasma
              Cheers Jason, HSS blade, front tool post lathe in reverse with power feed 440rpm.
              I will check the items you mentioned, got to be some thing simple as never had it before.
              Plus now I come to think of it blade snapped a few weeks ago and i reversed it, may have upset something.
              Mick
              #409542
              Jeff Dayman
                @jeffdayman43397
                Brass bar can slip in the chuck jaws too. Suggest using paper strip between bar and jaws, and tighten securely. Just snug is not good enough. Suggest doing all the other good suggestions re tooling so far.
                #409552
                HOWARDT
                  @howardt
                  If you snapped the blade then it may be plain HSS. I had this happen to mine and changed it to a M42 HSS-Co8, had a few snags but the blade has remained as one.
                  #409554
                  Nigel Graham 2
                    @nigelgraham2
                    I'd certainly take the above advice, but I've also noticed subtly convex ends on normal facing. Cross-slide worn / out of adjustment? That would affect parting, too.
                    #409560
                    Mick B1
                      @mickb1
                      Minimise partoff tool protrusion. If it's a thin blade there's a lot of lateral elasticity that even slight out-of-squareness on the cutting face will cause deflection, so only have the length protruding you need to reach centre.
                      Make sure topslide backlash is taken up toward the chuck. Make sure the blade is parallel to its direction of travel.
                      #409565
                      Paul Lousick
                        @paullousick59116
                        This is a good video on Youtube by Joe Pieczynski about parting tools.
                        Paul.
                        Hopper
                          @hopper
                          By far the most common cause is as Jason says: end of HSS tool not ground square and/or tool blade not set dead square to lathe axis.
                          #409638
                          Ian S C
                            @iansc
                            The parting tool should be flat on the top for brass(bottom if going in reverse), and dead square across the end or it will pull to the leading point. An angled end seems ok in steel.
                            Ian S C
                            #409642
                            blowlamp
                              @blowlamp
                              Posted by Plasma on 16/05/2019 19:32:36:
                              Mick
                              What do you mean when you say "and I reversed it"?
                              HSS parting blades are usually asymmetric,viewed from the front, so the cutting clearances will go to hell if you managed to flip it over to use the back end of the blade.
                              Martin.
                              #409651
                              Ian P
                                @ianp
                                If the parting blade is wedge shaped in section, then its important that its holder clamps it so the side clearance is the same angle each side. Certainly worth checking that there IS clearance on both sides. DAMHIKT.
                                Another thing I have wondered about with the wedge shaped blade is that the top edge is also at an angle so only go in the holder one way. If the cutting edge is ground dead square then only at one point is the cutting edge at the right height. I assume that causes some differential cutting action across the width of the cut so and therefore some blade deflection?
                                Ian P
                                #409663
                                Mick B1
                                  @mickb1
                                  Posted by Ian S C on 17/05/2019 13:51:32:
                                  Ian S C
                                  I think that's true and have noticed it more in softer materials, as you suggest.
                                  Sometimes you ain't got much choice but to got for an angled end, such as when you're parting a component with a through hole, you don't want a parting-off 'collar' around it, and you'd have difficulty holding the component to remove it in a second op. Then you just gotta see if you can get everything else on your side.
                                  #409791
                                  Plasma
                                    @plasma
                                    Hi all,
                                    I reground the cutting tool to ensure it was square across and it made all the difference. Parted off nice and square.
                                    Many thanks for the help with this one, there were some suggestions I will be trialling some of them with my parting set up for different materials.
                                    Regards Mick
