Parallel Machine Files
Home › Forums › General Questions › Parallel Machine Files
  • #382358
    Smike
      @smike
      Trying to locate a supplier in UK for files for my bench filing machine. Any ideas anyone ?
      thanks for your help
      #26310
      Smike
        @smike
        Supplier in UK ?
        #382367
        Brian Wood
          @brianwood45127
          For round files, use chainsaw files. As for others, you will have to research those yourself
          #382378
            They are very hard to source in the UK, most people resort to importing from the US. It might be possible to buy direct from a Swiss manufacturer.
            daveb
              @daveb17630
              You need to search for PARALLEL MACHINE FILES. Good luck with that!
              I had the same problem about 12 years ago, easier to get bull feathers! I eventually bought some from Federal file co in the USA for my bench machine (files, not feathers), they are a similar size to Swiss files. (I have an unused set of these PM if interested). I could not find any new or used files for my large filer so I bought a set of Swedish files (no particular reason for buying Swedish except the shop had a set in stock that looked as if it would do) 12", round, flat, square, tri, half round, etc. I cut off the non parallel parts and ground the ends to fit my machine, 60 degree point at bottom, 1" square tang at top to fit chuck, cuts on down stroke. Medium or coarse files are better, you will die of old age if you use fine files on these machines. If you haven't used a filing machine before, hold downs are essential if you value your fingertips.
              Harold Hall designed a small filing machine some years ago, he made some suggestions on modifying standard files, should be some info on his website. Daveb
              #382675
              Colin G
                @coling
                ‘Smike’ I sent you a message 2 days ago, still unread.
                Please log in on this site and go to your inbox. Colin
                #382867
                OuBallie
                  @ouballie
                  Smike
                  Harold Hall has details of converting normal files to work on filing machines.
                  Geoff – Slowly recovering from my '111' ordeal early this year, and resulting 6 visits to hospital.
                  Edited By OuBallie on 29/11/2018 11:21:54
                  Edited By OuBallie on 29/11/2018 11:22:35
                  #646161
                  Francis Milsom
                    @francismilsom24920
                    Many thanks – just what I've been looking for.
                    #646173
                    Ady1
                      @ady1
                      Do hand files not cut on the upstroke while machine files cut on the downstroke?
                      #646175
                      Bruce Voelkerding
                        @brucevoelkerding91659
                        If you search YouTube for "Blondihacks", you will see She is currently making a Die Filer. I imagine she will be dealing with the Files in the next week or two. I believe she is located in Canada.
                        #646185
                        Bazyle
                          @bazyle
                          Posted by Ady1 on 22/05/2023 11:53:25:
                          hence the mention of 'converting'
                          #646194
                          Trevor Drabble 1
                            @trevordrabble1
                            Axminster Tools sell swiss Vallorbe parallel files , listed as hand files , depending on what sizes you are looking for .
                            #648305
                            Bruce Voelkerding
                              In "Blondihacks" latest YouTube (Let's build a Die Filer, part 9) she completes the Die Filer. At 8:27 she mentions a US source for proper Die Files made for Die Filers. She does mention the company has stock and when the stock is sold off that's it. At 9:14 she makes her own Die Files in the Video.
