Paint removal
Paint removal
Home › Forums › Workshop Techniques › Paint removal
  • #15657
    Glyn Davies
      @glyndavies49417
      #128335
      Glyn Davies
        @glyndavies49417
        Hi. A few years ago I renovated an old Optimus stove (a 111, that is integral with its steel case) by derusting the case, then spraying with aerosol (acrylic?)grey primer, then metallic green, then with clear laquer. The problem has been that all these layers of paint have never really hardened and every time I used the stove, the paint softens and the stove glues itself to whatever surface it is resting on.
        So I decided to remove the paint and maybe get the case hot dip galvanised. Or just a flash over with a thin coat of metallic green without primer or laquer.
        I liberally daubed the case with paint and varnish remover, hoping that the soft paint would blister and disappear with a blast from the jet wash. No such luck. All the paint remover seems to do is to partially disolve and soften the paint, turning it into goo that is not easy to scrape off to bare metal.
        Can anyone suggest a way of effectively removing the paint layers. I assume if I am to get it galvanised, every scrap of paint needs to go. I had wondered about buying some caustic soda and making a concentrated boiling solution that I could dip the case in, but am wary of the hazard involved as well as its effectiveness.
        Thanks
        #128337
        Richard Marks
          @richardmarks80868
          Otley
          Take it to the local furniture stripper to get rid of the old paint and then spray it with heat resistant paint that is used for woodburners in any colour you like.
          Dick
          #128338
            In days gone by, Nitromors would do exactly what you hoped.
            … Regrettably the recipe was changed a few years ago.
            Sorry, I have no idea if there is anything comparable now.
            … You will probably need to resort to much scraping.
            MichaelG
            #128346
            Michael Cox 1
              @michaelcox1
              Hi Otley,
              Hot concentrated caustic soda will remove most paints very quickly. However, cold 10% solution is also effective but it takes much longer. Immerse the stove overnight and check in the morning. If necessary repeat the treatment.
              Make sure there are no aluminium, zinc or soft soldered components as these will dissolve in caustic soda. Most brass is OK although the caustic soda will remove zinc from the surface and the colour will become "coppery".
              #128348
              Ian S C
                @iansc
                If you use washing soda, and do the job electroliticly as if you were removing rust, you should get rid of most any type of paint. Make up the mix in a plastic container, use a battery charger, or similar power supply, connect the neg to the work, and pos to a bit of scrapmetal as an electrode. Ian S C
                #128351
                paul rayner
                  @paulrayner36054
                  I used some spray on mr muscel cleaner and sealed it in a airtight plastic box
                  had to do it twice but they came up a treat
                  Paul
                  #128361
                  Glyn Davies
                    @glyndavies49417
                    Thanks for the replies. I used the electrolosis with washing soda method when I first did the renovation to remove the rust from the case and it was quite effective. But won't the paint act as an insulator and stop the process?
                    As a quick test, I'll pour some hot caustic soda solution into the case tonight and see if anything happens.
                    #128365
                    Gordon Wass
                      @gordonwass
                      The best way to remove paint, if at all possible , is a blowlamp and wire brush. Acrylic is a bit difficult as it just goes hard and powdery instead of burning, but still comes off.
                      #128375
                      duncan webster 1
                        @duncanwebster1
                        If caustic soda doesn't shift it try cellulose thinners.
                        #128390
                        Cyril Bonnett
                          @cyrilbonnett24790
                          Brake fluid is a good paint remover just leave it soaking for a day or two, my son even uses it to remove the paint off his metal model buses when he changes companies.
                          #181883
                          Chris Pattison 1
                            @chrispattison1
                            Sand or the more kinder borax blasting might do the trick.
                          Home › Forums › Workshop Techniques › Topics
