On/off at the top with red green lights. What edge finder I?
Home Forums Workshop Tools and Tooling On/off at the top with red green lights. What edge finder I?
  • #401802
    Daniel Robinson
      @danielrobinson12697
      The engineering company was predominately Bridgeport CNC and this was in a cupboard that was being cleared.
      The on/off switch is on the top, red green lights signal the depression of a switch on the side of the device.
      I know it must be some kind of edge finder but does anyone know if it is Bridgeport or what machine it is for?
      Any help greatly appreciated.
      Daniel Robinson
        #401808
        Tony Pratt 1
          @tonypratt1
          From your description it sounds like a tool length setting gauge in the Z axis, a photo would be helpful.
          Tony
          #401809
          roy entwistle
            @royentwistle24699
            A photograph would help. You can see it,  we can't
            Roy
            Edited By roy entwistle on 23/03/2019 11:10:40
            #401817
            Daniel Robinson
              you Guys are fast plus it was a bit of a senior moment….
              Pics
              #401821
              Tony Pratt 1
                @tonypratt1
                Posted by Tony Pratt 1 on 23/03/2019 11:05:53:
                Tony
                Haven't got a clue now I can see it.
                Tony
                #401825
                  Posted by Tony Pratt 1 on 23/03/2019 12:32:59:
                  Could it be a custom Go/NoGo indicator, for one hole size ?
                  [Daniel] … Try putting a micrometer where thumb and finger are currently shown, to check when the lights switch.
                  Edited By Michael Gilligan on 23/03/2019 13:52:22
                  #401827
                  Philip Powell
                    @philippowell34749
                    Looks like a sonic screwdriver…
                    Sorry, I'll get my coat.
                    Phil.
                    #401840
                    Tony Pratt 1
                      @tonypratt1
                      Daniel are there any makers marks on it?
                      Tony
                      #401842
                      Daniel Robinson
                        Not a sausage. I even opened it up and there is nothing to hint as to what it is. It’s not “Heath Robinson” so I can only think that it is commercial but from who is anyone’s guess hence coming to the fountain of all knowledge.
                        #401845
                        Daniel Robinson
                          HI Michael,
                          Thanks for pitching in. you got me thinking and I have found the lights are confusing.
                          On the one side is a ground hard stop of 12mm diameter. The other side is the plunger that has a travel of 2mm.
                          the battery could be on its last legs (4SRR44 Photo batter 6.2V silver oxide) but still measures 6.2v output.
                          ….the lights were working and now they are not…. Bugger
                          Edited By Daniel Robinson on 23/03/2019 17:51:31
                          #401857
                          Martin Connelly
                            @martinconnelly55370
                            I think Tony P got it with z axis setting. Try the micrometer as suggested by. Michael G and see what repeatability is like (when it is working again) .
                            Martin C
                            #401863
                            Daniel Robinson
                              Thanks Guys, I will get another battery and give is another bash.
                              #401937
                              John Haine
                                @johnhaine32865
                                I doubt that it is made for use with CNC as it doesn't appear to have any connection for the probe input.
                                It isn't a tool height setter (i.e. Z axis) because the button operating axis is at right angles to the longitudinal axis which would go in the chuck.
                                It wouldn't be a useful edge finder because they need rotational symmetry which this doesn't have at the business end.
                                The configuration is reminiscent of a telescopic bore gauge, but the end of the cylinder opposite the button seems to be machined flat, which wouldn't allow it to contact the bore at a single point.
                                What it would do is act as a go/no-go gauge to measure a slot width, that's what I think it is.
