Noob question on scales
Home › Forums › Beginners questions › Noob question on scales
  • #119891
    Thomas Gude
      @thomasgude37285
      Hey.
      Can someone please tell me what the 2", 3", 4" scales signify?? Mainly relating to Traction Engines. Is it scaled from foot to inch? so a 4" model would be 4" for every foot of the real thing? So a 4" scale would be bigger than a 2" scale?
      Also, what is the largest people build up to regarding traction engines? Is 4" the accepted maximum or have people ventured into 6"?
      Thanks
      #6708
      Thomas Gude
        @thomasgude37285
        Traction engine 2″, 3″, 4″ etc
        #119894
          Thats right its the inch to the foot so for the same given prototype a 4" version would be twice as long as a 2" version.
          6" engines are becomming more common though most are of smaller subjects so are not that much larger than a big 4". For example a 6" model of the Burrell Gold medal Tractor has the same size boiler as a 4" Mclaren road loco.
          There are also the odd 9" engines about.
          J
          #119896
          Anonymous
            Posted by JasonB on 15/05/2013 12:02:32:
            Well it would be odd, it's all in the integer. wink
            #122488
            Thomas Gude
              @thomasgude37285
              Thanks for clearing that up. Almost fainted when looking at the prices of some of these!
              What is the smallest scale that is capable of running under steam? Do people run 2" scales under steam and if so what fuel do they use?
              Also, are there many traction engine volunteer clubs? They seem to be pretty sparse – I imagine because they're all privately owned…
              edit: I am in the Surrey/Sussex area
              Edited By Thomas Gude on 17/06/2013 13:21:06
              #122489
                You can steam a 1" or even smaller but if you want something to pull you around then 2" is the minimum I would suggest particularly if its going to be on grass.
                The very small 1" engines are sometimes better run on gas or charcoal but 1.5" and above will run on coal.
                Some of the museums have traction engines in their collections so if you volunteer there you may get to play on a big one. Amberley Chalk Pits has a couple of full size as well as a good model traction engine Rally usually in september.
                J
                #122501
                Swarf, Mostly!
                  @swarfmostly
                  Hi there, Thomas,
                  You could see a good selection of engines and other models at the Guildford MES annual show on 20th & 21st July.
                  See http://www.gmes.org.uk/rally.htm for details.
                  Best regards,
                  Swarf, Mostly!
                  #122712
                  Paul Lousick
                    @paullousick59116
                    Check out http://www.tractiontalkforum.com in the Model section.
                    Lots of info about model traction engines.
