On
18 April 2025 at 16:18 old mart Said:
… try increasing the looseness of the meshing, I find that tight meshing makes the most noise.
Me too, and so does an overly loose mesh. Like others I use paper sheet to set the gap, and experiment showed a double thickness of 75GSM laser printer paper gets best results on my Chinese lathe. A 3 sheet gap is too much, and 1 sheet too little. I don’t normally bother, but fiddling with the exact mesh between all the gears finds a sweet-spot where noise is noticeably less.
Although paper is recommended for spacing change gears, keep an eye on the type used, because paper is inconsistent. Newspaper is much thinner and squishier than the heavy gloss used in posh magazines.
Gears are inherently noisy! My lathe’s larger steel gears ring like bells, the sharp edges of the teeth audibly stir the air at certain speeds, and slight inaccuracies in tooth form and wheel diameter cause clatter.
One or more plastic gears in a train reduce noise considerably. But opinion is divided: many perceive plastic gears as cheap fragile rubbish to be replaced with metal pronto versus those who want plastic gears to keep the noise down. And apart from noise, a plastic gear in a train might be protective. Hobby machines aren’t built to gouge metal quickly and a weak plastic gear in the train is one way of protecting a delicate tool from heavy handed owners. The hope is the plastic will break, like a shear pin, before something more expensive. If metal must be removed quickly, buy a big machine, ideally industrial!
Final tip, only engage change gears when the lathe is fine-feeding or threading.
