Newton Tesla lathe package
Home Forums General Questions Newton Tesla lathe package
Viewing 16 posts - 26 through 41 (of 41 total)
  • #583434
    Samsaranda
      @samsaranda
      Surely with multiple earth conductors to one equipment you can end up with parallel earths that in certain circumstances can build up a lethal potential, I seem to recall some deaths being caused from this type of situation when I was in the Air Force, this was on power sets supplying power to aircraft electrical systems. I witnessed hefty blue sparks leaping to the airframe from independently earthed equipment being used on aircraft connected to ground power units, “wiggly amps” not my trade so I learned to treat this condition with respect. Dave W
      John Haine
        @johnhaine32865
        All a very interesting discussion but could anyone run a rule and possibly their phone camera over how the unit mounts to the Myford stand please?
        #583441
        ega
          @ega
          My unit is 210 wide x 280 high x 90 deep (front to back) and has c 10 wide flanges top and bottom for mounting.
          #583443
          John Haine
            @johnhaine32865
            That's brilliant ega, many thanks. One other thing – what is the mounting hole spacing please? And are there holes at top and bottom flanges?
            Thanks, John.
            #583445
            Clive Steer
              @clivesteer55943
              The requirement for two earth usually applies for industrial equipment and a lathe, although being used in a domestic environment, is still industrial. A usual the requirements are written in such a way that they do not necessarily describe the solution just the needed requirement. So the requirement may specify the need for a "fault disconnection device" known to me and others as a fuse. If you look on the back of some equipment you'll see the the normal IEC 3 pin connector for the mains power and close by a threaded post with a earth symbol next to it. This is for the second earth wire. A lot of domestic devices don't need a second earth because there are no exposed conductive parts that can be touched by a "Standard finger".
              The second earth on a industrial machine may be via the metal conduit the supply comes through and if there is a flexible section there should be a seperate earth wire wrapped around the flex tube in case it gets stretched and becomes disconnected.
              The normal PAT test does not cover the electrical tests needed to prove product compliance.
              Check out IEC 61010 and IEC 60204-1 if you can't get to sleep at night.
              Clive S
              #583451
              Clive Steer
                @clivesteer55943
                To cover another point that was made regarding earth wires. Earth wires shouldn't carry anything other than fault currents and then only for the time needed for supply disconnection. If it is then it is a supply connection intended or otherwise. There are complications where a supply wire is bonded to an earth wire eg neutral to earth and early electrical standards or lack of standards caused dangerous situations. This could arise if one bit of kit was connected to another bit of kit made to a different standard. All wires, just like any aircraft propeller, should be treated as live until proven otherwise and electrocution isn't an appropriate method of testing.
                Clive S
                #583462
                ega
                  @ega
                  Posted by John Haine on 01/02/2022 12:03:31:
                  Thanks, John.
                  There are two c 5mm holes in each flange symmetrically placed at 160mm centres.
                  Incidentally, my unit is on the right of the lathe stand and near to the mill which it also serves, an arrangement agreed with NT, saving money and allowing a tolerably rapid change over.
                  #583475
                  John Haine
                    @johnhaine32865
                    That's perfect! Many thanks again.
                    #583486
                    Emgee
                      @emgee
                      Posted by Clive Steer on 01/02/2022 12:14:30:
                      Clive S
                      The second earth you refer to in a conduit supplying power to a machine is a supplementary earth to ensure the impedance of the earth return is a low enough value.
                      This additional conductor may not be required to have a low enough impedance value but is considered good practise in such an installation.
                      PAT is not designed to prove product compliance, it is to determine if the item is electrically safe to use.
                      The IEC papers you quote have nothing applicable regarding earthing.
                      Emgee
                      #583544
                      Clive Steer
                        @clivesteer55943
                        I think I did say that the PAT test does NOT cover the tests needed to prove product electrical safety compliance.
                        It's been some time (13 years) since I last had to read and design products to comply with the Machinery and EMC directives but as far as I recollect IEC 61010 was to do with product electrical safety. The specifications may not mention earthing per se as this is only one way of achieving electrical safety. A double insulated device doesn't need an earth and a lathe may be classed as such if the motor and associated electrical system are installed in such a way that a failure of insulation or clearance will not result in an accessible conductive part becoming live. However when the lathe is installed in a factory or workshop another assessment is needed to ensure the product remains safe to use and earthing may be needed and two earths one of which can be visually inspected helps maintain safety compliance which may be defined by the Factory Act or other electrical safety requirements.
                        Clive S
                        #583546
                        Clive Steer
                          @clivesteer55943
                          A quick check of IEC60204 shows there is a section on "Protective Bonding requirements, terminology and protection against electric shock" commonly called earthing by laymen.
                          Clive S
                          #583551
                          Emgee
                            @emgee
                            Posted by Clive Steer on 01/02/2022 22:28:41:
                            Clive S
                            Read your first post to see what you said regarding PAT.
                            Perhaps you can post copy of IEC 60204-1 5.3 and clause 6 to enlighten me further, particularly the section that states 2 cpc conductors are required.
                            IEC 61010 I found refers to lab measuring equipment, not machinery installations.
                            #583554
                            Clive Steer
                              @clivesteer55943
                              I don't believe the specs require two earths but if the electrical safety of a machine or instruments relies on a earth being present then a single failure of that earth connection could result in the machine or instrument becoming unsafe. One way to overcome this situation is to have two earths so if one failed there is the other. However if both earth wires are hidden then you may not know that one has already failed and you're back to single failure situation. Regular testing or a method to prove the earth is present before power can be applied is possible but a visual check is relatively simple to do.
                              Every a domestic ring main socket outlet has two earth wires and an earth wire from the socket earth to the metal back box in case the screws don't provide good contact or get left out. Another example is a domestic metal kitchen sink is required to have second earth in case one isn't provided by the pipework.
                              Clive S
                              #583556
                              Steviegtr
                                @steviegtr
                                Posted by Clive Steer on 02/02/2022 01:14:10:
                                Clive S
                                I think you will find that is called suplimentary bonding.
                                In my 50 some years as a sparky we never ran 2 earth wires . Sometimes the conduit was an earth & the installation would have an earth wire too. But a plugged in appliance with a 13a plug top fitted would never have a extra earth wire. Where would you connect it. I think were some are not understanding this is.
                                On my Myford lathe a young 1970's model. It had a cable with a 13a plug fitted . In the motor control box where the earth connected , there was another earth wire attached , which came out of the terminal box & bolted to the side of the lathe bed. Not sure if that was standard or done by someone over the years.
                                It would not hurt to take a earth from your incoming cable connection & run to the frame of any machine.
                                Steve.
                                #583578
                                John Haine
                                  @johnhaine32865
                                  It's unfortunate that a small aside in what was mainly a request for information has been derailed into an interesting but irrelevant discussion on electrical earthing! To be clear, I intended no criticism whatever of the NT system, I just commented on a Myford quality problem. Maybe people who want to carry on debating the safety topic could start a new thread?
                                  #583596
                                  Emgee
                                    @emgee
                                    Apologies for leading your post to a different topic but as you pointed out machine frame earthing is an important issue.
                                    I have no intention to post further on the subject.
                                    Emgee
