New to metal lathes – bore sizes?
Home Forums Beginners questions New to metal lathes – bore sizes?
Viewing 15 posts - 1 through 15 (of 15 total)
  • #396262
    Bill Pilkington
      @billpilkington38650
      What lathes have a spindle bore size of 35mm to 40mm.
      Bill Pilkington
        Spindle bore sizes
        #396267
        Jeff Dayman
          @jeffdayman43397
          You might look in lathes.co.uk website for comparative info.
          #396273
            Bigger ones!
            To get an idea of the relationship between size and bore in Far Eastern lathes have a look at Warco's website. If you click on a lathe's photo it will take you to its specification including the spindle bore. (Scroll down to the table at bottom of each lathe's blurb.)
            I think the first Warco machine to meet your criteria is the WM290. At 230kg it's the largest of the 'Variable Speed Lathes'. After that, look at the Gear Head machines which go up to 80mm but weigh about 2500kg.
            John Rudd
              @johnrudd16576
              Chester's Craftsman is 35, the Crusader is 38, but after that the money goes up lots…..
              Edited By John Rudd on 14/02/2019 16:37:36
              #396290
              Bazyle
                @bazyle
                A lot of the 12x?? advertised 37mm but there were reports some time back that they could be on or more mm shy of that. However owners have been known to correct that without detriment. Some sellers may be knocking off a bit from the manufacturer's 'spec' to avoid comeback.
                In the USA they advertise 'gunsmith' models which usually means a larger bore on a basic model.
                Edited By Bazyle on 14/02/2019 18:10:05
                #396295
                Chris Evans 6
                  @chrisevans6
                  My Taiwanese copy of a 14"x40" Harisson M300 has a 40mm bore. A necessity for me doing mainly motorcycle work and needing to hold fork stanchions. Lathe brand name is Excel.
                  #396298
                  Vic
                    @vic
                    Big bore on this one!
                    Richard –
                      @richard-3
                      Harrison M250 35mm
                      Harrison M300 38mm
                      #396341
                      David George 1
                        @davidgeorge1
                        Hi Bill in the past I had to turn long pieces and to prevent wobble of the piece sticking out of the rear we made a tube which fastened on the rear of the spindle like an extension and a ring cam closed down three jaws on to the long piece to hold and prevent run out.
                        David
                        #396387
                        Howard Lewis
                          @howardlewis46836
                          My Engineers ToolRoom BL12-24 (similar to Warco BH600, Chester Craftsman and their clones ) has a 5MT mandrel with a 38mm through bore.
                          So you are looking for a fairly large machine., bigger than, say a Seig SC4 which is 4MT, I think.
                          #396418
                          Pete Rimmer
                            @peterimmer30576
                            The smallest lathe I know of which qualifies is a South Bend Heavy 10 which passes 1-3/8" (34.925mm) through the spindle.
                            Edited By Pete Rimmer on 15/02/2019 16:49:22
                            #396457
                            Chris Evans 6
                              @chrisevans6
                              Posted by Pete Rimmer on 15/02/2019 16:49:07:
                              That may depend on the year of the "Heavy Ten" my 1942 model sold about 6 years ago was only around 1 1/8"
                              #396475
                              Pete Rimmer
                                @peterimmer30576
                                Posted by Chris Evans 6 on 15/02/2019 20:03:23:
                                Good point. It's not the year, but the spec but yes there were some heavy 10's with the smaller bore just like there were some other sizes with the larger. The larger bore are by far the more common and identified by the 2-1/4" spindle thread.
                                #396485
                                Chris Evans 6
                                  @chrisevans6
                                  Thanks for the knowledge Pete, I thought all where the same and I had mine 45 years ! Great lathe only sold to make way for a bigger machine.
