New (to me) small, old lathe; how to proceed?
Home › Forums › Beginners questions › New (to me) small, old lathe; how to proceed?
Viewing 18 posts - 26 through 43 (of 43 total)
  • #116762
    Sub Mandrel
      @submandrel
      Hi Rod,
      Grimbledon Down eh?
      Roderick Jenkins
        @roderickjenkins93242
        Posted by Stub Mandrel on 13/04/2013 10:25:31:
        Hi Rod,
        Grimbledon Down eh?
        You've seen straight through my obfuscation. Were you there too?surprise
        Rod
        #116766
        Ian S C
          @iansc
          An old 1450rpm 1/4hp induction motor would be ok, if the market for old motors is similar to here, ten pounds should see you right if you have to buy one, I'v got 4 here, and two 1/6hp ones, they just keep turning up. Some motors it would be worth making a cover so that the motor does not get filled with rubbish. Ian S C
          #116789
          Sub Mandrel
            @submandrel
            I've just rescued one from the tumble drier, a simple VxA calculation suggests about 150 watts. Fitted with a poly-v pulley too.
            Also the clockwork timer switch and a relay worth keeping.
            Ian S C
              @iansc
              Neil, has the motor got a casing around it, or is it like a couple I'v got about that size, just the stator with a skeliton around it to hold the bearings, I suppose when its hidden away inside a dishwasher, there does not need to be too much metal around. Even the old 1/4hp washing machine motors have more holes in the case than a Swiss cheese. All these holes are a bit of a worry with all the bits of swafe flying about. Ian S C
              #116822
              Sub Mandrel
                @submandrel
                Hi Ian, it's an open frame, I think what is often described as a squirrel cage – wouldn't hold any of our local squirrels for long! Plenty of ways to 'swarf proof' it.
                Ian S C
                  @iansc
                  Ah Neil, the squirrel cage is the type of armature in the motor, common to all (almost all) induction motors. Ian S C
                  #116998
                  Sub Mandrel
                    @submandrel
                    Now I've learnt something today! Still don't see how they fit squirrels in there? Do you have squirrels in NZ?
                    Peter Tucker
                      @petertucker86088
                      Bald tailed squirrels.
                      (rats(
                      #322432
                      bugbear6502
                        @bugbear6502
                        Either my little lathe is worth a fortune, or there's an extreme optimist on eBay.
                        Listing of a Flexispeed Meteor II, in fairly rough condition, out of focus and/or shaky photographs.
                        Starting bid £900.00, collection only. surprise
                        BugBear
                        #322438
                        Hopper
                          @hopper
                          Posted by bugbear6502 on 20/10/2017 08:53:25:
                          BugBear
                          Glue sniffer!
                          #322548
                          Howard Lewis
                            @howardlewis46836
                            Bugbear 6502, I was given an old sewing machine and stripped it down for the motor, "in case it came in handy".
                            Whereabouts are you? I'm in East Anglia, so it can be yours, PM me if you want to collect it.
                            #322594
                            peak4
                              @peak4
                              Bugbear, just noticed this resurrection of your old thread. I too have a Simat 101, bought back in the '80s, and am looking to get it up and running again one day soon.
                              Do you still have an electronic version of the manual available please?
                              Thanks
                              Bill
                              #323925
                              bugbear6502
                                @bugbear6502
                                Posted by Lambton on 08/04/2013 17:43:12:
                                You will probbly have to machine a chuck back plate to suit the lathe spindle then any suitable diameter chuck can be fitted to this backplate.. If you can only justify buying one chuck always go for a 4 jaw independent chuck..
                                I have looked into making a backplate, and it appears technically "plausible"
                                However, I can't find any trace of small (enough) chucks that actually use a backplate. All the small-enough 4 jaw independent chucks seem to have a one-piece body.
                                This is further supported by the fact that the smallest semi-machined backplate I can find is 4" ; even the "tiny" mini-lathes are 7×10 (and up) where the Simat is 4×12 (aka 2×12 in English).
                                Although… checking the advert the Simat is 5 1/4" in the gap, so a LOW profile chuck could have a large diameter. But "low profile chuck" and "having a back plate" are again contradictory.
                                BugBear (googling for information and products)
                                #324573
                                john carruthers
                                  @johncarruthers46255
                                  I'm a bit late but if you look in my Flexispeed album there is a manual for the Meteor II, very similar to the Simat 101.
                                  bugbear6502
                                    @bugbear6502
                                    Posted by john carruthers on 31/10/2017 08:53:33:
                                    Already found, downloaded, and collated in to a single PDF – Thank you!
                                    BugBear
                                    #325305
                                    Adrian Giles
                                      @adriangiles39248
                                      My Simat 101 is powered by an AEI 1/4 hp motor, 1425 rpm, probably ex washing machine. I must admit i admit I like the little lathe, it has several very good features, I still use it occasionally although I use my bigger CJ18 most of the time. I bought the Simat brand new several years ago but didn’t use it for some years, before preparing for retirement, and relearning everything I thought I knew.
                                      Adrian
                                      #325683
                                      bugbear6502
                                        @bugbear6502
                                        I'm just in the process of sawing and filing up some TINY pieces of the metal for gibs.
                                        BugBear
