Posted by Neil Wyatt on 25/10/2017 20:58:27:
Just get a lathe with a decent distance between centres and a decent fixed steady.
^^This. (There's a reason he's the editor!)
My old Drummond has about a 3/8" hole up the spindle so almost all long work is done using a fixed steady. Works just fine. Just takes an extra two minutes to set up the job. I recently machined some hammer marks off one end of my under-restoration Myford ML7 leadscrew by spinningit in the Drummond with fixed steady in place, (and bronze bush over the leadscrew thread where the steady rubbed.)
For motorbike steering head spindles, you probably want to machine them between centres anyway, to ensure concentricity of the bearing seats, so lathe spindle bore size may not be relevant. Or at least machined in one setting with one end held in the chuck and the other end supported by tailstock centre, then parted off at the chuck to finish, so again lathe spindle bore not relevant.
This way, any small lathe will do the job. C4 Seig anyone? Seems to be well recommended for new machines. Used Myford would be right size but buyer beware, it's like buying a 40 year old used car.
Edited By Hopper on 26/10/2017 00:06:16
Edited By Hopper on 26/10/2017 00:06:49
Edited By Hopper on 26/10/2017 00:08:02
