New member with Stainier Jubille Tank Engine
Home › Forums › General Questions › New member with Stainier Jubille Tank Engine
  • #349146
    DAVID TRUCKLE
      @davidtruckle87321
      HELLO , NEW MEMBER HERE I WOULD LIKE TO ASK YOUR ADVISE , I HAVE INHERITED A 3 I/2 GAUGE STANIER JUBILLE TANK ENGINE AND THE REGULATOR IS STUCK ( CLOSED ) AND I CANNOT MOVE-IT , STANDING FOR MANY YEARS WITH OUT USE , IS THERE ANY WAY THAT IT CAN BE FREED , THE MOTION SEEMS TO HAVE A SLITE PASUE AT ONE POINT AND THEN I CAN TURN THE WHEELS AGAIN SO YOUR THOUGHTS AND HELP WOULD BE APPRECIATED .
      Edited By JasonB on 07/04/2018 10:09:25
      #25928
        J Hancock
          @jhancock95746
          Stop.
          Even if it did work, I would hope you were not intending to just try and 'steam it up' !
          Back to the problem, first remove the dome and have a look inside.
          My guess is , you will break a few screws doing this, so that will slow things down a bit.
          Now , see if you can see any movement at all between what you are trying to move( the regulator handle) and the mechanism of the regulator.
          If so,fill the boiler with a weak citric acid solution, go to bed. When you get up just try, gently, to move things again.
          If not, you will have to remove the whole assembly from the backhead ( more broken screws) and do it properly.
          #351610
          DAVID TRUCKLE
            @davidtruckle87321
            HI , I HAVE HAD NO JOY TRYING TO MOVE THE REGULATOR HANDLE AFTER SOAKING THE BOILER AND REGULATOR WITH THE CITRIC ACID , SO I REMOVED THE HANDLE , AND THE SCREWS AT THE BACKHEAD BUT I CANNOT WITHDRAW THE SHARFT WITH THE STEAM VALVE , AS IT IS STUCK SOLID , SO I HAVE REMOVED THE TOP HALF OF THE SMOKE BOX , AND REMOVED THE DOOR AND REMOVED THE BLOWER , AND WITHDRAWN THE SUPERHEATER AND ALL PIPE WORKS , AND HAVE BEEN ABLE TOO CONNECT A COMPRESSER LINE TO RUN THE AIR THROUGH THE CYLINDERS AND GOT THE WHEELS TOO START TO MOVE AND FREE IT ALL UP , AND HAVE BEEN BUSEY OILING ALL MOVING PARTS . BUT…. I STILL CANNOT REMOVE THE REGULATOR SHAFT … SO PLEASE I NEED SOME ADVISE HOW TOO REMOVE IT AS I AM STUMPED . DAVE.
            #351618
            J Hancock
              @jhancock95746
              You need to remove the dome, just in case it has a pipe up into it from the regulator tube.
              if it has a pipe ,remove it.
              Now, smokebox end .
              When you removed all that pipework , you should have seen a piece of plain pipe with an O-ring seal sticking out
              into the end with all the pipes on.
              Pray you did , because otherwise it will be impossible to get out without breaking something.
              Back to the large flanged end on the boiler backhead.
              You say you have removed all the screws, well done.
              Now you have to be brutal and somehow or other grip, pull and twist that flange out of the boiler.
              All of the regulator tube has to come out.
              There is no other way.
