Need help choosing a lathe chuck
Home Forums Workshop Tools and Tooling Need help choosing a lathe chuck
  • #802330
    not done it yet
      @notdoneityet
      My choice would not be from epay – as per Stuart Smith 5 earlier.  There are always rejects among these cheaper items – and some may well be sold by ebay sources with little or no chance of recompense if not to specification.
      Russell Eberhardt
        @russelleberhardt48058
        Have you considered German suppliers?  I live in France and have bought a lot of tools from Germany.  No problems with customs duties or currency conversion charges.  You could ask Seig-machines.de or even look at amazon.de as they have a very good returns policy.
        Russell
        #802497
        Howard Lewis
          @howardlewis46836
          The C1 is a micro lathe, so do not fit too large a chuck of any type, because the overhung load will over load the bearing behind the chuck, and shorten its life.
          And a big chuck takes up bed space in what is already a small lathe
          Also, the inertia of a large chuck chuck will call for a lot of power from the an already small motor to accelerate it up to speed.
          Also with only a 150 watt motor there is not the power to handle large work in a large chuck
          60 mm and 2.5″ 4 jaw chucks were available, but I would advise against going beyond 80 mm.
          At least with a 4 jaw independent, one set of jaws can be reversed (Although I always use them in the same slot in the chuck body)
          So it can be possible to work with one or more jaws reversed, relative to the others, if need be.
          With self centering chucks, whether 3 or 4 jaw  they can only be used in the same slot whether using the internal or external jaws.
          It would seem likely that most UK suppliers would be prepared to ship to Finland, at a cost. ASK!
          HTH
          #802585
          th1980
            @th1980
            Thanks a lot, what a helpful society this is! Soba it is then. I shall heed the warnings and will order from UK. Shipping is £31.68 from Cronos and probably some fees at the customs. I’ll look at the options and decide.
            #802602
              Are you mixing it up with the C0?
              The C1 came with 80mm chuck as standard as the spindle PCD is 66mm
