Mystery square nuts
Mystery square nuts
Home › Forums › Beginners questions › Mystery square nuts
  • #312403
    Bodger Brian
      @bodgerbrian
      In the box where I keep the change wheels for my mini-lathe, I recently found a handful of square nuts. I think they're imperial sized, 3/8" square x 1/8" thick with a thread size that I have no way of measuring.
      I'm fairly sure they are related to the lathe in some way but the big question is – what are they for?
      I think I can feel a 'Doh!" moment coming soon….
      #8834
      Bodger Brian
        @bodgerbrian
        Mini lathe parts?
        #312408
        Nicholas Farr
          @nicholasfarr14254
          Hi Brian, could possibly be 1/4" Whitworth nuts for gutter bolts, or more commonly called roofing bolts nowadays **LINK**
          Regards Nick.
          #312409
          Harry Wilkes
            @harrywilkes58467
            Same thought came to me when I read Brian's description of the nuts smiley
            H
            #312410
            Bodger Brian
              @bodgerbrian
              Nick – potentially, yes. But I'm sure they're related to the lathe in some way, as a) there are no other non-lathe related parts with the other bits & bobs & b) I've never had the need to buy or possess gutter bolts.
              #312413
              Nicholas Farr
                @nicholasfarr14254
                Hi Brian, it's just the thickness of 1/8" that made me think of gutter bot nuts.
                Regards Nick.
                #312425
                Brian G
                  @briang
                  Quick check is to try and fit an M6 bolt into them. If it looks like it will go but locks up solid, odds are it is 1/4 BSW.
                  I speak with the voice of bitter experience here, on taking over another company one of our storemen put all their 1/4 Whit hex nuts into the same bins as our M6. Luckily most of our stock (around a million nuts) was in sacks, but it was cheaper to scrap our loose stock than sort them.
                  Another Brian
                  #312430
                  Martin W
                    @martinw
                    Could they be for securing the gear axles/studs to the banjo and fit in a slot at the back of the banjo, square so they don't rotate when the axles/studs are tightened.
                    Just a thought
                    Cheers
                    #312433
                    Enough!
                      @enough
                      Is hardware for a mini-lathe likely to be imperial-sized?
                      #312441
                      not done it yet
                        @notdoneityet
                        If only 1/8" thick, they may well be nuts used in glass house construction where the nuts and bolts were rather smaller than the usual guttering/roofing articles.
                        #312449
                        Bodger Brian
                          @bodgerbrian
                          Posted by Martin W on 17/08/2017 00:37:47:
                          Thanks for the suggestion. I can't check it at the moment as I'm at work but definitely something to investigate later.
                          #312450
                          Bodger Brian
                            @bodgerbrian
                            Posted by Bandersnatch on 17/08/2017 01:39:28:
                            In my naivety, I assumed it was but now you mention it….
                            Must check out other fastenings this evening.
                            #312546
                              Similar nuts are supplied with some small vertical slides instead of t-nuts, they have an M6 thread IIRC.
