Myford VM -B milling machine
Home Forums Manual machine tools Myford VM -B milling machine
  • #401748
    Keith Long 1
      @keithlong1
      I am thinking of buying a second hand Myford VM-B milling machine. The problem is that it is in a basement of a house. The back of the machine appears to be held down to the base with 4 cap head bolts. I am tempted to undo the 4 bolts to see if it comes apart to make it easier to lift up the stairs but I am worried that I may do more harm than good. I would be grateful if anyone has any information or any ideas that may help
      Keith Long 1
        @keithlong1
        Can a Myford VM-B milling machine be split in two
        #401752
        John Haine
          @johnhaine32865
          I have a VMB and I can confirm that undoing those bolts will free the column from the base. It will be very top heavy because the motor is mounted at the top of the column driving the spindle through a long splined shaft. I would recommend that you first lower the head as far as it goes and remove the motor before even trying to loosen the bolts, and take great care as you remove the column that it doesn't topple over. Then you'll have the opportunity to tram the column vertical when you reassemble the machine! I've had my VMB for many years and I'm very happy with it now I've fitted a VFD and 3 phase motor and got rid of the stupid intermediate pulley.
